Question about Fisher Paykel EcoSmart GWL15
Fisher&paykel gw712 washes but wont spin and drain
Hi. My fisher & paykel gw712 fills and washes ok but stops when it comes to rinse. After about 5 minutes it starts beeping and if i hit the start button, the red lid lock light comes on and just stays like that. Any help would be great as the washer is only 3 years old, and they want $125 plus parts for a guy to come out. Thanks
  • mann433 May 11, 2010
    washer bad fisher paykel leaking and dead
Fischer paykel leaks and just plain died
Posted on Apr 29, 2010
Hey,
Mine has started doing the same thing. Any ideas on what could be wrong? Thx.
Posted on Jan 06, 2013
    Problem Solver:
  • 14 Answers
You probably have a blocked drain hose - the most common cause is a coin or a button but sweetie wrappers & paper are just as bothersome. Turn off the machine & unplug. Pull the machine forward so that you can access the rear. The drain hose is at the bottom of the rear of the machine and is held in place by a very strong spring-loaded clip or else a jubilee clip. This needs to be removed & will result in the water inside the machine & hose draining out so make sure you have plenty of containers & cloths/towels etc to catch & mop up. The blockage is usually located just inside the hose. Remove anything you find. Also check the hole on the machine where the hose attaches. Re-attach hose. Clean up, put machine back and switch on. Also check filter for clogging (see manual). Run machine on rinse & spin cycle. Hopefully that should do it. Good luck.
Posted on Feb 20, 2015
My Fisher Paykel washing machine won't spin it's goes to rinse then stops. The wash light and the last rinse light comes on also spin light comes on and it's beeping
Fisher & Paykel technician in your area
Contact
Http://www.fisherpaykel.com/au/support/service-appliances#
request-a-service
Customer Care - Online Locator
Feb 18, 2016 | Fisher Washing Machines
Fisher and paykel model gw712 . During rinse or spin cycle unit goes out of balance and stops. The rince or spin light flashes and a beeping sound is heard.
your clothes load is too heavy on one side; stop it move some around and turn it back on and see if it doesn't wobble all over.
Jun 06, 2015 | Fisher and Paykel Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Water not pumping out F&P GW712
If you can hear your pump running then your drain hose might be clogged, if not it is probably the pump and will need more in depth troubleshooting.
Oct 25, 2009 | Fisher Washing Machines
Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Sep 14, 2009 | Fisher Washing Machines
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Sep 21, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
1,742 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
