Question about Braun Health & Beauty
Hi, my Babyliss i-trim 7855U shaver has stopped working, my little brother tried an incorrect power supply and now it doesn't recognize the original and won't charge or anything. Please help, thank you!
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
bono1
  • 32 Answers
SOURCE: My charger won't work
All I can say is that you'd better buy a new one cause 7 years it's more then better
Posted on Aug 19, 2007
SOURCE: Braun 5520 Shaver Stopped Working
order a replacement 5520 PCB assembly. it is very easy to replace. remove the two bottom cover next to the charger and remove the two screws. slide the unit out and pop off the black plastic cover. remove the defective PCB battery module and insert the new one. replace the black plastic cover and slide the shaver back into the shell. charge annd it ready to go.
Posted on Dec 17, 2007
SOURCE: braun 6512 shaver stop working
hi i would say that you have major problem with this did you drop it sounds like a problem with the circuit contact braun or shavers uk kevin.
Posted on Dec 19, 2007
SOURCE: red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Posted on Feb 06, 2009
BaByliss 2082CU Pro 235 Hair Styler these won't seem to heat up enough on highest setting, brand new
Enter the serial number on the babyliss website to ensure you have a genuine hair styler, if genuine ask for your equipment to be swapped or repaired at there cost
Feb 23, 2015 | BaByliss Health & Beauty
I overcharged my babyliss grooming kit now it won't work
You will have to get new batteries. In Greece, there are specialist battery shops that supply or charge batteries for every possible use. One of these shops replaced my batteries for 8 euros and now my hair trimmer is as good as new again. The trimmer appears to take two common AA sized rechargeable batteries, so you should be able to change the batteries yourself.
Jul 01, 2014 | BaByliss 7053U Beard Trimmer
Need replacement foils for model 8667BU as mine is broken
hi my foil babyliss machine was broken how can iget new foil for model 5667bu
Jul 09, 2011 | BaByliss 8667BU
I have lost the charger for my Babyliss 7053u, where can I find a new one?
A new kit is fairly cheap: http://www.amazon.co.uk/BaByliss-Men-7053U-Over-Grooming/dp/B002FGTJ0O
I couldn't find just the charger anywhere... I would recommend just buying a new kit.
Apr 21, 2011 | BaByliss 7053U Beard Trimmer
My babyliss 789ou has lost the ability to set adjustment,this happened after travelling
This commonly happens to travelers. The voltage of electrical outlets differ depending on where you travel. Shavers bought in one country are specifically designed to handle the outlets of that country but plugging into a potentially higher output outlet you blow out the motor of your shaver which it seems like you did. The only real solution would be buying a new shaver. It had nothing to do with the shaver itself, simply a mix-up in charging the battery which caused the motor to overheat.
-Jord
Feb 28, 2011 | BaByliss Health & Beauty
Need new battery for babyliss trimmer
Here you go: http://www.cellpacksolutions.com/rechargeable_shavers.asp
Jun 26, 2010 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Forfex blade reinstall
I have the Forfex babyliss 720 and I can't get new blades installed in it. I have tried 8 times and someone else has tried 5times. Do you have any instructions on this model.
Thanks
lchardt@embarqmail.com
Dec 16, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Health & Beauty Logo
787 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
