Question about ASUS K8S-MX Motherboard
Ram problem.. Hello sir, I am having K8S-MX mother board. when am working in my system, am getting black and red colored lines as well as some times my monitor is not switching on. 1 year back only i changed my 256 DDR1 ram for the same problem and now also am getting the same. so what could be the problem.
    President:
  • 2,351 Answers
Carthi, I do not think the problem your having currently has anything to do with your memory. If your video card was integrated into the board I might agree there could be a problem with your memory but that is not true. Your video card is an AGP8x device. Black & red colored lines can be produced from either a bad monitor or a bad video card. Your K8S-MX motherboard can not run DDR1 ( unless you mean that slot 1 DIMM you replaced). Your board only supports, 2x184-pin DDR DIMM sockets for up to 2GB non-ECC PC3200 / PC2700 /PC1600 DDR DIMM's. No video display suggests your video card may be going bad or monitor is going bad. To prove this concept, please temporally switch your monitor with a monitor you know functions correctly. If you can not temporally switch your monitor with someone else than replace your AGP8x video card. You can find up to six pages of AGP8x video cards listed at the link below.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
The XFX cards carry Lifetime Warranty.
If you find you have more questions feel free to ask.
Good Luck & Kind Regards.
Mike
Posted on Mar 24, 2008
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Asus k8s mx mother board problem
To get rid of this message at boot you must turn off the Chassis Intrusion detector feature. To do this you must restart the computer, as it boots press DEL to enter BIOS.
Under the SECURITY tab in BIOS select CHASSIS INTRUSION and select DISABLE.
Then select EXIT and SAVE CHANGES and OK to reboot the system.
Jan 31, 2009 | ASUS K8S-MX Motherboard
THE SLOT OF AGP CARD IS LOOSE WHAT'S THE OPTION?
first use ur on board display card for this
pick out ur agp card from agp slot and then check ur display if it is ok then change ur agp card if it is not ok then clean ur ram and re insert in motherboard and then chk if same then try with other ram moduel.
Jan 29, 2009 | ASUS K8S-MX Motherboard
Overclocking Failed K8S-MX
There should be a jumper to reset the CMOS, look in the manaul to locate it. And ya.
Jan 22, 2009 | ASUS K8S-MX Motherboard
To download Asus k8s-mx motherboard driver
Hi aneeshkem,
All the driver's for the Asus K8S-MX motherboard are listed at this link.
http://support.asus.com/download/download.aspx?modelname=K8S-MX&SLanguage=en-us
Enjoy!
Mike
Jul 31, 2008 | ASUS K8V-MX Motherboard
Not able to install RAM > 512 MB
Try to run a system repair.
Jul 14, 2008 | ASUS K8S-MX Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
ASUS K8S-MX Motherboard Logo
78 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
