Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Laptop connection where is the connection for a lap top to a 37 inch flat screen philips tv, and what type of connection is needed
  • Philips Master
  • 8,457 Answers
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Posted on Apr 27, 2010
Yellow tinge to whole tv screen
if a crt type set a bad solder connection or connections are present at end of the crt on that board there.
Jun 11, 2012 | Philips Televison & Video
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
My 2 yr old 37 inch 1080 p magnavox tv will cost 244.00 to repair. Is that too much ? I already paid this guy 45.00 to diagnose.
That is about normal. Sounds like a lap or control board plus labor charges which can be all the way up to $80 an hour.
Jan 12, 2010 | Philips Televison & Video
Need codes for Philips flat screen TV model #27PT6441/37 in
U recieved the propeer code from a nother direcTV provideer in my area. It worked when others did not.
Oct 07, 2009 | Philips Televison & Video
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Not able to connect my lap top to to the monitor
the laptop should have a special area under display properties and goto settings you should see 2 screens if not it might need the top addres bar settings change and you will have to choose which screen is the primary and secondary and if you click to verify the screens the screens should have a number of which is the primary is 1 and secondary is 2 on the screen and if you have the icon to change these setting near the clock then try right clicking it and it should be up a option screen and it should should have the option to output to monitor and screen....
Dec 01, 2008 | LG M1910A 19 in. LCD Television
Out of range
Out off range means the resolution coming out of your laptop is too high. Remember it's the res. of your second monitor you'll want to change. I'm thinking it'll be 1024x768 max, but may even by lower. Hope this helps.
Jan 22, 2008 | Bush WS6671 28" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
283 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
