Question about MSI P35 NEO COMBO-F ATX M/board - Intel P35 Chipset, 1333MHz FSB, Dual DDR3 800/1066 DDR2 667/800, P... Motherboard
Ram upgradfing i know the modules say on msi its 1066, but will it handle 1333 mhz ram or better?
  • 75 Answers
Yes it can
Posted on Apr 27, 2010
Can i install 4 GB RAM for acer G41T-AD V:1.0 motherboard?
Yes. The specs are
2 x 240-pin DDR3 DIMM slots Supports Dual Channel DDR3 1333/1066 MHz non-ECC, un-buffered memory (Max 4GB)
Jan 07, 2015 | Acer Computers & Internet
How to install memory in a Gigabyte silent pipe motherboard
First, you must determine the applicable memory to your motherboard by reading the manual or it should be indicated in the box.
Ex.:
1600 (O.C.)/1333/1066/800 MHz FSB
4 x 1.8V DDR2 DIMM sockets supporting up to 8 GB of total system memory
With the above details, you can buy up to 4 memory modules, each with a maximum of 2GB. You can also choose your preferred FSB, 1333/1066/800MHz but you can tweak the system and choose the overclock module, 1600MHz. Remember to carefully install your memory module to the memory slot, the notch will give you an idea on how it'll perfectly fit. The left & right holder of the memory will produce a sound after you carefully install the memory modules thus, also indicating of a successful installation.
Hope this gives you a lot of help!
Thanks for using FixYa!
Aug 19, 2014 | Gigabyte Computers & Internet
Ram supported for z580/5 5933347 lenovo
The Ideapad z580 series takes DDR3 SODIMMs, either PC3-8500 (1066 MHz) or PC3-10600 (1333 MHZ)
It can go to 4 GB (2 x 2 GB SODIMMs) in 32 bit or 8 GB (2 x 4GB SODIMMs) with a 64 bit OS. Here is the Kingston page, although they have discontinued these models Memory Discontinued Models
Jun 27, 2014 | Computers & Internet
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
    You may have tried to put too much memory (RAM) onto it.
    That models maximum spec is:
    Memory upgrade information:
    • Four DDR3 DIMM (240-pin) sockets
    • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
    • Supports Dual channel memory architecture
    • Supported speeds
      • PC3-10600 @ 1333 MHz*
      • PC3-8500 @ 1066 MHz
        *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
    • Non-ECC memory only, unbuffered
    • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
    • Supports up to 4 GB on 32-bit PCs
    You can find the specs and troubleshooting help files here
    Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
    Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
    you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
    Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
    Just bought the acer g5900.Memory DDR3 what i want to know is whats the MHZ 1066 or more.
    MHZ is the speed of the RAM, this is very important to know because all RAM in a computer MUST be the same speed. In example that a 800 MHZ RAM cannot work together with a 1066 MHZ RAM, otherwise the computer will not boot.
    Mar 23, 2011 | Acer Aspire Predator (AG7750U2222) PC...
    I have a new MSI p45neo fs main board with E7400 cpu. Could you help me? What should I set the JB1 JB2 Jumpers at 200,200-266, 266-333, 333-400 mhz. The system has 4gb of ddr2@667 and a MSI n9400gt graphs...
    You can set the jumpers to:
    JB2 - Pins 1 and 2
    JB1 - Pins 2 and 3
    200->266MHz
    Your CPU has a FSB of 1066 MHz. (See http://ark.intel.com/Product.aspx?id=36500 )
    The system uses a "4" multiplier, so the freq. for the above settings would be 800 - 1066 MHz.
    You can overclock the CPU at your own risk using the other settings. I would not recommend it, but many do. Better safe than sorry.
    Thanks for using Fixya.
    Jan 30, 2010 | Computers & Internet
    Purchasing RAM
    DDR3 modules can transfer data at the effective clock rate of 800–1600 MHz using both rising and falling edges of a 400–800 MHz I/O clock. In comparison, DDR2's current range of effective data transfer rate is 400–800 MHz using a 200–400 MHz I/O clock, and DDR's range is 200–400 MHz based on a 100–200 MHz I/O clock.
    decide urself, depends onur system support and ofcourse ur buying capacity.
    DDR3 is better
    Oct 30, 2008 | Computers & Internet
    MSI P35 NEO COMBO-F ATX M/board - Intel P35 Chipset, 1333MHz FSB, Dual DDR3 800/1066 DDR2 667/800, P... Motherboard Logo
    145 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    David
    David
    Matthew Spark
    Matthew Spark
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
