Lands Phones Logo
Posted on Mar 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone to laptop away from modem
Want to use my phone as link to my laptop,when I am away from my home modem.
Anonymous
Level 2:
  • Expert 32 Answers
  • Posted on Mar 24, 2008
Anonymous
Expert
Level 2:
Answers
32
Questions
11
Helped
11300
Points
101
First of all you need to conect between you phone and you Laptop, you can do it either by cable or by blutooth,
now once they are connected you need to define your phone as your modem in your laptop.
If you could give more details as which laptop you use and which phone the explantion will be esier
1helpful
Why wireless not working with my smart phone but the laptop via wire?
Probably because your home network (by which I mean your modem/router) is not wireless (WiFi). That's also why you have to "wire" your laptop to your network with an Ethernet cable, instead of using it wirelessly.
I have an acer laptop and there is no place for a phone line and i want to seat up internet
Modern laptops are doing away with phone modems. If you need to use a dial-up and this computer has no built-in modem, you will have to purchase a PCMCIA card to put in the side--one that is a modem.
2helpful
I have wireless connection with a 2 wire modem and every time my home phone [ cordless ) rings or someone is on it ,, i lose my internet connection . Ive put a splitter on the cords and everything and it...
The reason why your experiencing that problem was the cordless phone and the router that youre using has the same 2.4Gz frequency.So everytime the phone rings it interupts the wireless signal what i can suggest is if the phone is in between the computer and the router or if the phone is near the router move it away so that it wont interfere the wireless signal
Thanks for using Fixya.
Can I download modem on dell laptop
Most of the time on laptops if there is no phone input for a modem you cannot just plug in and dial up. The process i use at home for my pc is dialing through my cell phone. If your carrier will allow you to tether your phone without extra charges check your phone manufacturers website for modem software. You then just connect your phone through a usb cable and set a internet connection matching your carriers instructions. Another solution is dificult without networking knowledge but you can set up a home pc with a wireless antennae as a ad-hoc server through internet connection sharing and then allow your laptop to connect through the "server" pc.
1helpful
Don't have home phone and looking to buy router/modem.
Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
1helpful
2answers
Nokia 6070 internet connection
www.blogfortech.co.cc
go to this link u will find the PC suite for Serial cable
Download that and install on your PC/laptop
Connect ypor mobile to PC/laptop via CA-42 cable
When youR phone gets connected to your PC/laptop
go to control panel and then in phone and modems and
go to modems and select add new and click on 'dont insatall my modem i will select from the list'
after that select manufacture nokia and select modem of NOKIA 3200 and select the port ON WHICH YOUR PHONE IS CONNECTED
dont select the different port you will not be connected to internet.
and finish it
NOTE:-Install your modem only when your phone is connected.
Go to PC suite and click on the modem you installed
and provide your Operator setting and you have done it.
NOTE:-when your connection is Established your Phone will be disconnected from the PC suite
After disconnecting from the internet Your phone will again connected to PC suite.
ENJOY...........
Jan 08, 2009 • Cell Phones
2answers
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Vista Home new computer causing busy signal on home phone
In the modem there are two link one for the phone and other for the line . In the line link you have to connect the direct phone line and phone link you have get the extent cable, link it and connect it to the phone . try it and porb comes inform to fixya.com
Wireless telephone interefrence with wireless broadband
hi.. be sure that your router is at least 6-8ft away from any other device such as a modem or phone.. i have the same router and have no intereference with wireless home phone or cellular.. i hope this helps.. what type of interference are u having with your broadband? good luck, donna
2answers
Sprint PCS treo phone as modem--cannot get on the internet!
I had a similar problem. I had to upgrade the Connection software. I have the Treo 700WX. if you go in to ur program and then to Modem Link. Set it as connection via usb. Install the drivers for the phone then see if the Sprint Connetion software sees ur phone and service.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
