Question about Denon AVR-687
Denon AVR-687 cannot power on, no power light lit around power
Cannot power on, no power light lit around power button. Internal fuses good. Seems like power supply has died.
  • 3 Answers
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Posted on Apr 30, 2010
I have a old denon avr-1804. try to switch on power but can not. just appear a main power red light flashed rapidlly. please tell me why?
Greetings
the red flashing LED is that the Device is in protection mode.
the internal power supply . +15 volts and -15 volts are defected you need to be replace it ... Regulators 7915 and 7815 .... these you should change , might also need to check capacitors .
these are common defects for Denon . AVR units.
Good Luck
Hope this helps
May 26, 2016 | Denon Audio Players & Recorders
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
No sound from my ja 687 amp lights show receiver is working
Need to check on the power supply to the output drivers, if there is no response on the speakers it is possible that the output replay is under protection. You need to remove power plug and leave aside for an hour before the amplifier is plugged back. If all functions show on display but there is no sound check the PREAMP output- audio out. If there is audio then the fault is with a non switching of the power amp or a power amp protection. Since these are mounted boards with little access to testing you need to be skilled to go further to probe and proceed. Also Denon might refuse to service if the amp is tampered which also can be expensive.
Oct 25, 2011 | Denon AVR-687
Hi, I'd like to use my Denon at overseas where
There should be a switch that you could set to the various voltages. Normally a round switch in one of the corners on the rear panel that you can turn with a flat screwdriver
Aug 02, 2009 | Denon AVR-687
Denon AVR 1506
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Feb 09, 2009 | Denon AVR-1506 Receiver
Denon AVR-687 Logo
769 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
