Question about WYSE S10 (90210501) Network Terminal
How to flash a Wyse S10 without network? Can use usb!
  • 9 Answers
SOURCE: network printer through thin print in wyse s10 model
not sure look in the manner
Posted on May 20, 2008
  • 154 Answers
SOURCE: Wyse S10 RPD to Server 2008
you have to buy 1 terminal license for you S10 also.
Posted on Apr 23, 2009
  • 25 Answers
SOURCE: wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
Posted on Jul 07, 2009
SOURCE: Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Posted on Oct 07, 2009
SOURCE: how to unlock usb port at wyse s10
WYSE WTOS OS is the most secure OS and one can not play around with unlocking USB ports
Posted on Dec 15, 2009
Wyse s10 an windows server 2012
Guys who need windows 10 key can go link http://windows10productkey.weebly.com to got. My key got here and after i used is great works. Hope it help you.
Nov 11, 2013 | WYSE S10 (90210501) Network Terminal
How to unlock usb port at wyse s10
Dec 03, 2009 | WYSE S10 (90210501) Network Terminal
Apr 23, 2009 | WYSE S10 (90210501) Network Terminal
How do I enable print screen botton
Depending on what keyboard you use, you may have to press the "F" toggle key to enable print screen.
Feb 19, 2009 | WYSE S10 (90210501) Network Terminal
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
USB printer crashing thin terminal when 'out of paper"
Wyse ThinOS firmware updates are chargable, or you need a maintenance contract in place for major firmware changes.
Going from 6.1 - 6.2 would be chargeable, but getting the latest version of the firmware version you are currently on should be free.
You are best off talking to your reseller or Wyse
Oct 20, 2008 | WYSE S10 (90210501) Network Terminal
Hard Reset
Youch, thats a pickle!!
Basically, because the terminal is in loopback mode when in the OS, you would need to find an up to date .i2d file, and for the S10, then try and re-image it with Wyse Simple Imager. This will use PXE and DHCP option tags to grab the device, and push an image to it.
Make sure PXE is first in the boot order in the BIOS, people often forget this!!
All the software you need (apart from the i2d file) is available from the Wyse website. When it comes to the i2d file, you will need to contact Wyse directly to get hold of this.
http://www.wyse.com/serviceandsupport/support/downloads.asp
Jun 04, 2008 | WYSE S10 (90210501) Network Terminal
Wyse PXE boot error
All Boot devices in BIOS may need to be set to "NONE". When shutting down, select "Shutdown and Restart the system, then hold the "Delete" key down while clicking the OK button. Keep holding the "Delete" key until system restarts in setup. Password that I was given is "Fireport". If that gets you access, then set all boot order configuration items to "NONE", then "Save Values and Exit". Hope it works for you as well as it did for me.
Feb 08, 2008 | WYSE S10 (90210501) Network Terminal
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
WYSE S10 (90210501) Network Terminal Logo
256 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
