Question about Fisher and Paykel Dishwashers
Hi. I have a "Dishdrawer" F & P dishwasher DS603 range. I cannot start it to ceommence running a wash. There is no error code flashing, the power is on, and the door is closed properly. Whan i press start, it makes 3-beeps and simply does not start. I have tried turning it off, but this did not fix it
aborcass
  • 2651 Answers
SOURCE: Fisher & Paykel Dishdrawer DS603
2 quarter sized circles on either side of drawer will release the drawer fronts and allow acess to the electronics, behind the bottom drawr taped to back wall of unit is a troubleshooter/techsheet which might prove to be very helpful
Posted on May 02, 2008
SOURCE: FDB1050REC2
Follow up to my Jun 02, 2008 post. We had a service tech come out today, and it turned out that the door switch was bad. The neutral side had continuity with the door shut, but the hot side was sporadic. A new switch has been ordered.
According to the Frigidaire tech sheet attached to the door, which is located beneath the control panel and behind the door skin, the problem could potentially be a bad control panel also.
Hope this helps someone in the future!
Posted on Jun 03, 2008
biigg53566
  • 89 Answers
SOURCE: My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Posted on Nov 18, 2008
stephanos18
  • 144 Answers
SOURCE: beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Posted on Mar 24, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
How do we put it through a test mode?
Here you go, both answers :>)
Bosch Dishwasher Troubleshooting Your Bosch dishwasher can run a test cycle which will quickly go through each stage of a wash programme in order to find out at what point a fault is occurring. It will only give you a general idea of where the problem lies but is a useful first step in diagnosing the issue.
The steps to start the test cycle vary depending on what model you have but the basic method is similar across the range. It might be that your dishwasher doesn't have the same button labelling as described in the steps below. In that case try holding down the buttons which have similar names. After a little trial and error you'll find the right combination.
  • Make sure the dishwasher is switched off.
  • Press and hold the Power Scrub Plus and Regular Wash buttons.
  • Turn on the dishwasher, then release the two buttons.
  • The light above each of these buttons should flash.
  • Start the test cycle by pressing the Power Scrub Plus and Regular Wash buttons again.
  • The test programme will begin and an error code will be displayed at the end of the cycle if a fault has been detected.
You can find a list of Bosch dishwasher error codes and their definitions here.
Error Codes are also here;
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Sep 30, 2015 | Bosch Dishwashers
DS603 fisher paykel motor noise when starting up
The pump and motor for DD603 is the same device. It is a rotor lodged inside a cavity under the drain filter plate. I am assuming the dishdrawer is drained properly and at end of the wash there is no water sitting inside. You need to take the rotor device out from its cavity and check for damage. This video will help.http://www.youtube.com/watch?v=UXzuJvKIIgU
Mar 26, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Our F & P dishdrawer keeps coming up with f1 and a picture of a spanner have tried turning the machine of at the switch for 24hr but is still doing it
Water has collected at the base of the dishwasher under the drawer.
This triggers a flood switch and causes the F1 error.
Turn the mains power off and extend the drawer out as much as possible. Take towels to dry the base from inside. Also use hair dryer ot dry out the flood switch mounted at the base.
Turn the power on and see if there is any difference. The cause of water collection could be many. Foam in detergent or kink in drain hose or drawer door gasket leaking etc.
May 11, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Leaking fisher & Paykel DS603 Dishdrawer
i think there is a hole in the grey sump underneath rotor motor, the motor is the grey blades u took out of sump. pull out drawer, take filter tray and rotor motor out of drawer, dry all of water out of drawer , then look underneath unit , pour a little water into drawer and see if it is leaking past motor windings . if it is then there is a hole in the sump. if it doesnt leak from there try looking at the little black drain hose. please turn off power b4 u work on dishwasher do not want any accidents . please reply 4 more help.please tell me what u find. good luck
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
77 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
