Question about Asrock 775i65GV Motherboard
My mother go to setup every time i shut down the computer or turn off power
  • 75 Answers
- set date time in bios or disable floppy drive
- change the battery on your mainboard
Posted on Apr 27, 2010
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
Shut it off
Explanation sounds like motherboard or SMPS problem.
Try removing all your cables from motherboard including hard drive and other cables. Make sure to note down the power button placement on mother to later set it up the same way. Also need to test motherboard
Unscrew your motherboard from the cabinet and tilt you cabinet, place some plastic or wooden peice on cabinet and put your motherboard over it. Connect VGA Cable & Keyboard to motherboard. Now connect the power cable to mother board. Looks like one in image and try powering on by connecting only powerbutton cables. See it allows you to on CMOS setup. If it does, try connecting hard drive cables and try booting up. If doesnt work, finally hope my recommendation might be of some information
Recommendation
Replacing either would be less costly then getting complete new computer. You already have rest of things just get a good & latest package of CPU and Motherboard.
May 23, 2010 | EliteGroup P4M800PRO-M Motherboard
Every time i turm my computer on the monitor comes on and then says going to sleep the computer shuts down will not stay on. I can"t do anything, it keeps shutting down and the monitor shuts down.
this is a computer problem not a monitor problem whens the last time you cleaned out the computer as in air blasted to clean out any dust if the power supply over heats this would cause a shut down the other thing would be a problem with the mother board open case look at the stuff inside and see whats dirty cpu, power supply , motherboard dust a #1 killer of motherboards
Dec 10, 2009 | HP Media Center M1050Y PC Desktop
Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Jul 21, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
No vedio
swap monitors if monitor is same dell brand then its the monitor. otherwise you can buy a Video card PROVIDED that you can disable from setup the MOBO video card, and install drivers, also speaking of drivers try uninstalling the video and monitor drivers first !! the do mon swap, finally new vid card .
funky things can happen to drivers, esp improper shutting down windows like flip a power switch or not having a UPS and computer shuts down during a power outage or storm. seen this happen as well.
Apr 26, 2009 | Intel D946GZIS Motherboard
THE SCREEN SMEARS NAD SHUTS DOWN
Hi eakesj:
A number of things here should be checked.
First shut down and remove all cards, and power connections to all the drives such as cdroms, hard drives.
The power supply should also be looked at and tested for correct voltages on each wire. This can be done with a voltage meter.
Turn on the power and see if you can get the machine to start to the bios screen. (this will work if you have a video processor on board, if you have a video card, you will need it to use the monitor).
If that will not work, then you have more problems than you thought at the beginning.
If the mother board will not work at this point, then you have problems with either the mother board or the cpu processor. There is a possibility that there are problems with the memory modules.
So, if you have only one memory module, then I would remove the memory, carefully clean the contacts, (a clean pencil eraser can work, if you are careful, and do not press very hard) and then plug the memory back in and try again. Also if you have extra modules of the same type, try one for testing.
If you are still having the same problems, then the mother board or the cpu is the problem. At this point you should consider if you want to continue and repair or buy another mother board of the same size. If you buy another kind of mother board, remember you will have to re-install your operating system over the original one to get the complete setup and the bios to work correctly with it. Many times this can be done, but you risk losing data (you will lose all data in MY DOCUMENTS), and may have to completely re-install the OS. You may want to install the drive in another computer as a slave and back up any data you want to save before you proceed.
If you decide to continue with your original mother board, and still have problems, then the cpu or the mother board is suspect. To test the cpu, either test your board with another cpu which is compatible, or check the mother board with another mother board of the same exact model.
Hope you find the problem.
Feb 03, 2009 | eMachines T6534 PC Desktop
AcerPower 1000 keeps shutting down
you mean the computer power off automaticaly.
check the all cable of mother board.
Jan 21, 2009 | AcerPower Sn PC Desktop
Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Computer won't acknowledge power souce - shuts down
Try taking the battery completely out and see if it works then.
Mar 26, 2008 | HP Compaq nc6320 Notebook
Computer shuts down y by itself
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
Dec 02, 2007 | EliteGroup 945GZT-M (V1.0) Motherboard
Asrock 775i65GV Motherboard Logo
63 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
