Question about Volkswagen Golf V Vw Red 1:18 Scale Diecast Model
I changed the rear disk's on my vw golf tdi mrk4 and now when i drive the pads smoke how do i adjust the handbrake
  • 632 Answers
You need to remove the armrest, hand brake console then you adjust the nuts for the left and right cable.
Posted on May 08, 2010
Wheel smokes,brake dragging
Make sure your handbrake cable is adjusted properly. Adjust the rear brake shoes down to where the wheels turn freely with the linings only just touching the drums. Be sure to pump the pedal a few times after adjusting, then try again.
The front wheels (pads and calipers) will just about never bind, so concentrate on the rear wheels. If you do suspect the front wheels, release the bleeder valve for just a second and then try again.
Jan 24, 2014 | 2001 Toyota Corolla
Just changed rear pads and rotors on my 2000 chev blazer..after test driving rear brakes were hot and smoking...brake pads seem to be sticking..are the calipers shot or do I need hoses or both?
  • Well when you looked at the brake pads after your drive were the pads stuck to the rotor?
  • First thing to do is double check your pad and rotor installation.
  • Also check to make sure the right parts were installed.
  • When you pushed back the pistons on your calipers did they flow back nice and smooth? Did they wedge in and get stuck? This would make the pads drag.
  • If you used grease did you get some on the pad by accident? If this is the case it will burn off.
  • How is the car stopping for you? Properly? Do you hear any grinding while driving slow? While driving fast? Over heating rotors will turn a bluish stain. That is when it is really time to be worried.
  • If your brakes are not dragging then give some time for the pads to ware in.
  • If the piston is stuck forcing the pads against the rotor all the time then you need to replace the calipers.
  • Don't forget to bleed the lines afterword.
Regards, Tony
May 17, 2011 | 2000 Chevrolet Blazer
How do I change the brake pads
piece of cake ,the pistons just push in front and rear ,the handbrake is inside the rear brake disk so dont forget to strip and lubrcate the operating mechanisms for the handbrake with some nice copperslip in the adjuster .Also most important is to polish it every week and clean seats with leather restorer every month after all it is a real car as its a JAGUAR
Jul 15, 2010 | 2003 Jaguar XJ-Series
Do I need any special tools or wedge to change a timing belt for 2001 tdi jetta diesel.
Timing Belt Spanner Wrench
AST tool# H 2587-1
- Used for the Adjustment of the Timing Belt
- Applicable to 2004-2005 VW Golf, Jetta Pump Duse and 2002-2005 Audi 3.0 V6
Used for the adjustment of the timing belt.
2009 Suggested user price: $52.67
Assenmacher Specialty Tools
1 800 525 2943
AST tool# H 2587-2
- Used for Adjusting the Timing Belt Tension
  • Applicable to 1999 and later VW Golf and Jetta, Passat and 1999-2003 VW Beetle with 2.0L Gas Engine and 1.9L T.D.I. Diesel Engine
Used for adjusting the timing belt tension and is comparable to VW tool# T10020. Applicable to 1999 and later VW Golf and Jetta, and 1999-2003 VW Beetle with 2.0L gas engine and 1.9L T.D.I. diesel engine.
1 800 525 2943
128947643
Jul 02, 2010 | 2001 Volkswagen Jetta TDI
Changing front and back brakes on vw golf tdi 54 plate
Replacing brake pads or rotors does not need to be difficult if you have the right tools. Volkswagen and Audi rear calipers require that the piston be rotated while being pushed back into the caliper.
May 04, 2010 | 2004 Volkswagen Golf
I need to replace the rear brake pads on my Polo 1.9 TDi
this is a turn in caliper, meaning that as you try to compress the piston, you also need to rotate it clockwise. you can buy tool for this at nearly any parts store, and is fairly inexpensive.
Dec 28, 2009 | Volkswagen Jetta Cars & Trucks
VW Golf TDI - loss of power and smoke from exhaust
Sounds like a piston ring has failed.Do a compression test to be sure its a ring or valve stem seal.
Jun 17, 2017 | Sony VPL-VW100 (Ruby) Multimedia Projector
How to replace rear disc pds on VW Golf 2.0 TDI 2006
Remove the wheel first.
In there you will see the brake pads.
The brake pads are held in place by the caliper. The caliper is secured with two 15 mm bolts, and two 13 mm on the opposite side.
Once you undo the caliper you should also find an apex clip on top op the pads.
Once you have done that , slide the caliper out and remove the pads.
To refit you may need to compress the caliper. You can use a clamp, but on VW I compress the caliper using a robust wooden stick as a lever inside the U shaped part.
Before putting the new brakes I use an hand file tool to mill the corners of the pad, this will increase aderence to the rotor disk.
Remember that the car will have reduced braking power when you install new pads.
Regards.
G.
Aug 17, 2009 | 2006 Volkswagen Golf
Rear brakes audi A4
wind them back in -the handbrake is self adjusting with the caliper
Nov 16, 2008 | 2002 Audi A4
Rear disc brakes freezing up
Master cylinder may be bad or most likley air in the lines---bleed the brakes.
May 27, 2008 | 2005 Ford F-150
Volkswagen Golf V Vw Red 1:18 Scale Diecast Model Logo
229 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
