Question about CTX Optoma EzPro 580 Multimedia Projector
Ctx ezpro 550m
Have you any of the lamps in stock for the above projector
    Problem Solver:
  • 12 Answers
Do a search for the lamp number on EBAY. if you don't have the lamp number, search by projector number and you should find several suppliers offering it.
Ebay is www.ebay.com
Posted on Mar 24, 2008
SOURCE:
Seeking replacement lamp
Try Bulbman.com or Bulbs.com or the retail chain called "Batteries PLUS Bulbs".
If they don't stock them, they should be able to point you toward someone who does. Good Luck !! Jim
Jun 06, 2014 | Braun Office Equipment & Supplies
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
Just replace my lamp with a new one, when i start my projector, everything seems to work fine but the lamp doesn't light up. the lamp light flashes green for 30 second, theres a ''motor'' sound in the same...
HI,
You can visibly inspect the lamp to make sure the bulb behind the glass is intact & the round part of the bulb is clear & round. Otherwise if possible return the lamp for exchange. If the same thing happens then the lamp ballast is likely bad. I have many in stock I can diagnose it.
Apr 14, 2011 | Sharp XR-10X Multimedia Projector
I have a Sharp Projector that recently flat lined due to the Lamp life ending. My question is, Will a cheaper $214.00 non-sharp product lamp be ineffective or will it work just like the in stock $559.00...
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 22, 2011 | Sharp Projector Lamp for XV-Z90U
Panasonic FHL 6EX-N (TOP BULB FOR ELMO EV4400AF VISUAL PRESENTER. Where can I buy it and how much?
We just go these from Interlight. Their part # FHL6EX-N
INTERLIGHT.BIZ
They had them in stock and shipped the same day.
Nov 23, 2010 | Elmo Projectors Elmo projector lamp...
Dell 3300 MP Projector
I think this is a lamp issue. Even though your lamp might have an advertised time of 3000 hrs from Dell, it can fail and dim a lot earlier than that. Often within 1000 hrs a projector lamp's brightness can be reduced by up to 40%. Projector lamps brightness and lamp life varies according to how you use your projector and the environment it is in. Our company sells projector lamps and has created a YouTube video to help people get the most out of their projector lamps. You can see the video below. If you decide to buy a new lamp we have the lamp you need in stock at Projector Lamp Experts.
Hope this helps..
Jul 15, 2010 | Dell 3300MP Multimedia Projector
How to reset lamp projector ASKProxima
Pressing and holding the Volume + and the Volume –, switch projector on and keep holding buttons pressed simultaneously for 10 seconds. If that fails, try the above method with projector on.
Jan 21, 2010 | ASK Proxima SP-LAMP-018 C110, X2 Projector...
InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Jun 23, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Discoloration
Please contact [email protected] for all your projector lamps needs. We provide orignal projector lamps with casing. We stock all Brands & Models avaialble in the market today.
Jan 21, 2008 | InFocus Litepro 580 Replacement Projector...
Open Questions:
See all CTX Optoma EzPro 580 Multimedia Projector Questions
CTX Optoma EzPro 580 Multimedia Projector Logo
158 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
Lampdeng.com
Lampdeng.com
Terry
Terry
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
