Question about Dacor Epicure EOG303 Grill
Dacor E0G303/ propane to gas?
Have propane dacor grill, trying tomconvert to natural gas?
  • gerry917 Apr 27, 2010
    thank you for info will contact local dealer for parts
  • 404 Answers
You will need to change the propane jets to natural gas ones. takes few minutes only, I think some appliances are actually having them as spare ones in case you need to change. they are not an expensive item just in case you have to buy them, and good thing you do not need a specialist to change them, to know how they look like just try to find a small nut with a tiny whole in it located inside the burner rings More information on the proper pressure settings you can find on http://www.dacor.com/Customer-Care/Manuals-And-Specs.aspx?TaxonomyId=155..
Posted on Apr 27, 2010
Howcan i switch a dacor erd30 from natural gas to propane?
it requires different jets and the air mixer adjusted
it is a job for a gas fitter and not a DYI
Mar 31, 2015 | Dacor Kitchen Ranges
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Trying to convert from LP to natural gas on my 36" Dacor grill. Is it possible? It is an 06 model and Dacor has told me that it can't be done, but the manual says it comes equiped to handle LP or...
If Dacor told you it can't be done, don't attempt it. It may have been OK, 5 years ago. But, something may have happened since then (a safety issue), that precludes it now. With that said, I'm sure there others on this site that will tell you it can be done. But, my 15 years experience in the Hearth and Home business, tells me, if the manufacturer says "No", it's not safe to do.
Besides, all you'll gain is convenience of not having to refill the LP tank. But, you'll lose the fast preheating propane provides and hotter flame.
Hope this helped you make the right decision. Happy Grilling!!
May 23, 2011 | Dacor OB36 Gas Grill
How to change a weber natural gas grill to propane
According to Weber, "There is no conversion kit available to convert any Weber gas grill from one gas type to another. Any attempts to do it will void your warranty."
Sorry, but if it's any consolation, Propane Gas burns cleaner and hotter that Natural Gas in an outdoor environment. Which translates into faster preheating and hotter searing temperatures.
Hop e this helps and happy Grilling!!
Mar 19, 2011 | Weber SUMMIT S-620 Propane Grill
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Converion kit to natural gas.
I don't believe Weber makes a gas conversion kit for your model grill. I say this, because your model grill comes two ways, Natural Gas or Propane. This indicates to me, that there's more than just changing the burner orifices involved.
I can tell you this ... If you could convert it to Natural Gas, you would soon discover that the grill doesn't preheat as fast as with propane. Nor, will it maintain heat as well as propane, in an outdoor environment. Propane burns cleaner and hotter than Natural Gas in an outdoor environment.
Sure, it may seem like a hassle to refill and change the tank, but I can assure you, you won't be satisfied with it's performance.
Feb 03, 2011 | Weber Spirit? E-310 Propane Grill
Our complex has two Dacor BBQs. Both give off very low heat. It takes 15 mins to get the temp up to 300 and that's as high as it gets. The flame to me look low (weak). Many times the flame cannot make...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 02, 2010 | Dacor Grilling
I just bought a used Dacor EOG36 and it is preped for natural gas< what do I need to to convert it over to propane?
you need a conversion kit. tried to look it up but can't find that manufacturer, at least in the 3 supply company's I use
May 29, 2010 | Dacor Epicure EOG36 (LP) All-in-One Grill...
Dacor pgm 365 lp to naural gas
Yes by a licensed person so as not to break any local laws or Kill You,
LPg typically delivers at a higher psi than natural gas, and the propane content requires more combustion air than the methane butane mix of natural gas,
methane CH4 needs 2 oxygen (O2) to make CO2 +2 H20
Propane C4H10 needs 7.5 (02) 4 CO2 5 H2O
the nozzle injecting the LPg has small diameter, The Gas certified plumber can remove the nozzle(s) and replace them with larger diameter Natural gas ones for a small price, most manufacturers make both, its a simple job
Cant stress - Gas Certified plumber/tradesman - strongly enough, one explosion will ruin your whole day
May 09, 2008 | Dacor Preference SGM365SS Gas Cooktop
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Epicure EOG303 Grill Logo
73 people viewed this question
Top Dacor Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Dacor Grilling Expert? Answer questions, earn points and help others
