Question about Samsung SPN4235 42 in. Plasma HDTV
My samsuNg PS42A410C1D has no picture. i cant bring up any menus or anything see anything but it is producing sound
    Novelist:
  • 58 Answers
The most likely thing is that your screens backlight or inverter has gone faulty.
When you turn it on, you may be able to see a very very dark image of something (best seen by activating the TV menu). On some screens the picture is still far too dark to be visible though.
With this kind of fault, its down to fitting a new inverter, and if that doesn't cure it, then fitting a new backlight bulb (or bulbs) will sort it out, but these are not jobs that can be done without some expertise at them.
Most TV inverters are large circuit boards inside, and take about 20-30 minutes to change as the whole TV has to be dismantled, but the backlight bulbs are much more complicated (and extremely fragile too).
Unfortunately, there's not much else that can be done except trying changing those 2 parts. Although its possible for the screen cable inside to become disconnected and lose your picture, that results in the screen lighting up brightly (usually pure white if the cable comes off completely).
Posted on Apr 27, 2010
No display or picture. has sound.
try resetting to factory default through the menus available from the remote control. The option should be in the general or settings menus. This may clear the fault. Check your antenna/aeria is working and correctly connected. If this produces no remedy it is possible that the sound output of your televisions motherboard has developed a fault or there may be an issue with the speakers or their connections to the motherboard.
Jun 13, 2015 | Vizio Eco VO320E 32-inch Class Television...
My samsung tv model UN29F4000, has sound but no picture, no menus come up. I'm not sure if it has a tconn board or not. What is the most common problem with a tv with these symptoms
The most of this TV problem is that the inverter transformer built on the main power supply is bad, to fix it, you may replace the transformer , or replace the power supply module.
Apr 06, 2015 | Samsung Televison & Video
My schreen has no picture. The camera still takes and downloads pictures ok but I cant use the viewer. The schreen lights up after you take a picture but no picture shows. I cant get into any menus to...
Sounds like either a bad LCD or a loose connection to the LCD. Very risky and time consuming to try to fix aat home. Diagnostics and service by a Nikon Authorized Service Center is advised.
Dec 21, 2010 | Nikon D70s Digital Camera
HAS SOUND BUT NO PICTURE
okay the reason that the its turning off could be the fan isnt spining fast enoug hold your hand at the back of the tv to feel where the exhaust air if isnt good enough to help cool off the bulb then the fan may need to be replaced also the balast could be going bad and last check the power supply that feeds the balast make sure its a constant dc voltage
Mar 28, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
Aug 13, 2009 | Samsung 50 in. Plasma TV
Picture problem with Beko 32WLH530HID LCD TV.
did you ever sort this as ive got the same problem
May 27, 2009 | Televison & Video
I can't change the date
Press arrow button to turn on LCD. Press menu/OK to bring up menus. Press left side of menu dial twice to bring up SETUP menu, then scroll down to date and time settings. You should be able to figure it out from there.
Jan 25, 2009 | Samsung Digimax S500 Digital Camera
Pioneer 501-HD 53 Rear Projection TV- No Picture or Sound
your input board might be bad, does it work on any other inputs?
Oct 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
U940 glide
Samsung has produced some defective phones.  I have had the same problem before. If your warentee is still active, you can bring your GLYDE into a VZW store and they will give you a new one for free. they will also transfer your contacts.
Aug 21, 2008 | Samsung Glyde SCH-u940 Cellular Phone
Samsung SPN4235 42 in. Plasma HDTV Logo
998 people viewed this question
Henry  Thomas
Henry Thomas
