Open the device manager and any devices showing under sound and audio devices or any other yellow marks
to open device manager right click on my computer and click properties
Yes goto your control panel, open Sytem and see Device Manager. If there is any icon with yellow color in the list, it means you have missing driver. If you have any missing driver that might be for your audio controller. If so then you have to install the driver for the device. Install the driver and enjoy.
Note: If you don't have driver then Ask Me for that with your sound card manufacturer name and model no.
Thanks
Iqbal
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
hope this helps
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
