Question about Nokia 3100
Switch off automatic switch off
    Guru:
  • 229 Answers
If your phone is using a memory card I guess you stuffed it with a lot of applications OR you are using a memory card that your phone finds hard to read.You will need to format the phone with this code, *#7370# immediately you turn your phone on.Note that you should use a sim card that has no useful info and your memory card needs to be removed, as this code resets and deletes every installed programs and returns your phone to its original state on production.I hope this info is useful. If you need anymore help or experience difficulties let me kno.
Mike
Posted on Apr 27, 2010
How do i get to the nettrual safety switch in a 1999 pontiac grand prix
Park/Neutral Position Switch Replacement
Removal Procedure
  1. Apply the parking brake.
  2. Block the wheels.
  3. Place the vehicle is the Neutral position.
  4. Remove the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  5. Click to Enlarge
  6. Remove the automatic transaxle range selector cable.
  7. Click to Enlarge
  8. Remove the wiring harness connectors.
  9. Remove the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  10. Click to Enlarge
  11. Remove the PNP switch mounting bolts.
  12. Remove the PNP switch.
Installation Procedure
Tool RequiredJ 41545 Park/Neutral Switch Alignment Tool
    Click to Enlarge
  1. Verify that the shift shaft in the Neutral position.
  2. ImportantDO NOT ROTATE A NEW PNP SWITCH. A new PNP switch is pinned in the Neutral position. If the bolt holes do not align with the mounting boss on the transaxle, verify that the shaft is in the Neutral position.
    Adjust the PNP switch if the new switch has been rotated and the pin is broken or if using an old PNP switch. Refer to Park/Neutral Position Switch Adjustment .
  3. Align the flats of the shift shaft to the flats in the PNP switch.
  4. Install the PNP switch to the mounting boss.
  5. Caution! Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  6. Install the PNP switch mounting bolts.
  7. Tighten
    Tighten the PNP switch mounting bolts to 25 N·m (18 lb ft).
  8. Install the automatic transaxle range selector lever. Refer to Automatic Transmission Range Selector Cable Lever Replacement .
  9. Click to Enlarge
  10. Install the wiring harness connectors.
  11. Click to Enlarge
  12. Install the automatic transaxle range selector cable.
  13. ImportantVerify that the engine starts only in the Park position or the Neutral position once the PNP switch is installed. Readjust the PNP switch and/or check the shifter and the automatic transaxle range selector lever if the engine starts in any other position. Refer to Park/Neutral Position Switch Adjustment and/or Automatic Transmission Range Selector Lever Cable Adjustment .
  14. Install the throttle body air inlet duct. Refer to Air Cleaner Assembly Replacement in Engine Controls.
  15. Remove the blocks from the wheels.
  16. Disengage the parking brake. Hope this helps, the page was read only so no pictures. Info is for 3.1L engine.
Jan 18, 2018 | Pontiac Cars & Trucks
My 2003 Oldsmobile altero gets stuck and i have to jiggle the shifter or leave it set for a min befor if will go from park to reverse ect.. Just got the car yesterday
Your problem is more then likely with the Automatic Transmission Shift Lock Control .This is a safety thing . Has a switch , wiring and a electrical solenoid .
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock control solenoid
• The automatic transmission shift lock control switch
• The park/neutral position switch
Sorry to here your having a problem with it already .
There are diagnostic step to find the problem , involves using a DVOM - digital volt ohm meter an using a wiring diagram to locate test points in the circuit . Plus you will need to take parts of your vehicle apart to get to those test points . The most likely part to fail is the park neutral safety switch . The contacts wear inside after hundreds of times of moving the shifter . But without testing this is just a guess .
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. With the transmission in the PARK position, the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, mechanically locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to move from the PARK position.
Apr 25, 2017 | Oldsmobile Cars & Trucks
05 Trailblazer transmission says neutral but gear shiftier is locked in park.
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
With the ignition in the ON position, voltage is supplied to automatic transmission shift lock control switch. Voltage flows through the normally closed contacts of the automatic transmission shift lock control switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid causing the transmission shift lever to be physically locked in the PARK position. When the brake pedal is pressed the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to be move out of the PARK position.
Circuit Description
The transmission range (TR) switch is part of the park/neutral position (PNP) and back-up lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The powertrain control module (PCM) supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. The PCM compares the actual voltage combination of the switch signals to a TR switch combination chart stored in memory.
These are all electronically controlled , yur best bet would be to take your vehicle to the dealer .
Apr 19, 2017 | 2005 Chevrolet TrailBlazer
2000 regal won't go out of park
I would think it has something to do with
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consist of the following components:
• The automatic transmission shift lock control solenoid.
• The automatic transmission park lock solenoid (Regal only).
• The automatic transmission shift lock control switch.
• The transmission range switch.
Regal
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control and park lock solenoids. The transmission range switch provides a path to ground in the PARK position. With the automatic transmission shift lock control and park lock solenoids energized the shift lever is locked in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control and park lock solenoids to release. This allows the shift lever to move from the PARK position.
Do the brake lights work ? If not could be cause by bad brake light switch .
Nov 28, 2016 | 2000 Buick Regal
Shifter is locked in park on a 2002 bravada that sayes on dash its in reverse
PRND321 Display
The instrument panel cluster (IPC) displays the selected gear position as determined by the engine control module (ECM). The IPC - instrument panel cluster receives a serial data message from the ECM indicating the gear position. The PRND321 display blanks if:
The ECM detects a malfunction in the transmission range switch circuit.
The IPC detects a loss of serial data communications with the ECM. The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The transmission range (TR) switch is part of the park/neutral position (PNP) and backup lamp switch assembly, which is externally mounted on the transmission manual shaft. The TR switch contains four internal switches that indicate the transmission gear range selector lever position. The PCM supplies ignition voltage to each switch circuit. As the gear range selector lever is moved, the state of each switch may change, causing the circuit to open or close. An open circuit or switch indicates a high voltage signal. A closed circuit or switch indicates a low voltage signal. The PCM detects the selected gear range by deciphering the combination of the voltage signals. The PCM compares the actual voltage combination of the switch signals to a TR switch combination chart stored in memory.
You need a Tech2 scan tool to diagnose this problem ! possible range sensor !
Sep 03, 2015 | Cars & Trucks
Abs light on wont shift out of park
Hi Judy , what kind of vehicle do you have ? Year an model ? ABS light has nothing to do with it not coming out of park . Problem with automatic transmission shift lock control ! Probably !
The park/neutral safety switch.
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The park/neutral safety switch provides a path to ground for the automatic transmission shift lock control solenoid in the PARK position. This energizes the automatic transmission shift lock control solenoid, mechanically locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to de-energize. This allows the shift lever to move from the PARK position. When the shift lever is out of the PARK position the contacts in the neutral safety switch open and the automatic transmission shift lock control solenoid is de-energized.
Jul 07, 2015 | Cars & Trucks
Where is automatic light switch on my 2004 buick rainer cxl model suv
There is no switch, they are automatic. There is a sensor mounted on the top of dashboard that senses light, which tells headlights to turn on.
May 24, 2014 | 2004 Buick Rainier
P1646 how much to repair
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
P1796 Automatic Transmission
as you can no such code exists for a jaguar ,contact code reader manufacturer
Jan 03, 2011 | 2004 Jaguar S Type
1972 moblile home heater does not work automatically
alot of times those switches go bad and poeple just by-pass them those switches operate in this fashion...when you put the fan to automatic it will only come on when the heat or cool is turned on when you put the switch to on the fan will run continueously ie the switch usually will be labled Auto- Off - On
Jan 06, 2009 | Heating & Cooling
Automatic switch off my sigmatel s3 mobile
automatic switch off mobile & it lost its phone data(my msg.)date and time
;my mobile setting will change
please send us solution for this
my email id chetanthorbole16@yahoo.co.in .
Thanks
chetan
Sep 30, 2008 | Handmark Software MobileLists (950142) for...
Nokia 3100 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
