Question about Motorola Mobility BT50 Cellphone Battery
My cell phone will not take a charge. It just
My cell phone will not take a charge. It just says low battery but will not take a charge. I have tried my home charger and the car charger. In fact, it started the not charging when i tried to charge it in my car tonight.
    Guru:
  • 229 Answers
Try out another battery, an original one
Posted on Apr 27, 2010
Nokia 2700c battery low problem
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Mar 04, 2012 | Nokia Classic 2700 Cell Phone
Low battery
It seems your phones battery's lifespan for some reasons maybe over.This may have been caused by:long hours charging/frequent charging even when the cells not dry.Try replacing the cell phones battery.
Hope this helps.Thanks.
Dec 28, 2011 | Alcatel OT708 Orange PrePay Mobile Phone...
Battery is dead wont charge and when i try to switch it on a red light flashes
Make sure that your battery terminals and the battery contacts are clean. Check the voltage of the battery and the voltage of the adapter in the battery terminals within the phone.
If you can use a jump charge externally if the battery voltage is below the set level as a last try it will be good. now try to charge for 12 hours, if the battery does not retain charge, replace.
However if the adapter voltages are low replace.
Sep 24, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Battery power is very weak
    1. Try this first  power off your cell phone and charge it for 6 hours
    2. remove the charger and power on your cell phone start using it
    3. please note that don't use your phone while charging unplug it if you need to use
    4. only recharge it when it shows battery is low
    5.  please buy and use original battery and  charge
    6. I am sure that you can see the difference
    Jun 20, 2010 | Nokia 6500 Slide Cellular Phone
    New cell phone battery trouble
    Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
    Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
    Every time I try to charge my phone it says "charging paused due to phone temperature being too high or too low" What causes this
    very hot battery ... batteries dont like to charge if they are very hot or cold.
    Turn your phone off and let it sit for a while before you try to charge it.
    Better yet, bet a second battery and change it regularly.
    Oct 13, 2009 | Samsung Propel A767 Cell Phone
    My mobill betry is so low and icant solution this problem so you can solv problem now thanks my name is piyushmistry &my cell no is 09824136819
    Hello Sir, If the battery is showing low battery then you should charge it with its corresponding Charger. I think you are willing to tell that the Phone is showing low battery even after charging. If that is the case then there can be 2 causes :--- (1) The Phone's battery is not properly plugged in and thus can't properly retain the Charge which is supplied. In this case, try cleaning the Battery Contact, I mean the 3 Power pins and the 3 power slots. Use something like dry cloth. (2) The Battery is damped or defective. If damp then don't try to charge, it can sometimes explode. Kindly take it to a Service Center and get it repaired.
    Also try changing the Battery.
    Thank you Sir, Have a nice day.
    Oct 12, 2009 | Samsung SGH-F250 Cell Phone
    Nokia n73 new battery charges quickly and
    try without memory card and if problem persists pls go to customer care...
    Aug 10, 2009 | Nokia N73 Cellular Phone
    LG chocolate phone/low battery/plugged in/constant beeps
    take your battery out & rub on the pins of battery. then put it in the cell phone & switch it on & charge it.
    Dec 20, 2008 | LG CHOCOLATE VX8500 Cellular Phone
    Motorola Mobility BT50 Cellphone Battery Logo
    537 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    D. E. Hev
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
