Question about Radio Communications
Hi can you tell me what a ztr-tester is used for
Hi can you tell me what a ztr-tester is used for please
How do you check a car battery?
Hi u can use a HYDROMETER cost aprox $16-00 on E/BAY this will tell u the condition of each cell. If it's a sealed battery u can use a battery LOAD TESTER APROX COST ON E/BAY $35 ...cheers
Jun 30, 2016 | Cars & Trucks
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
I have a ford f250 can't get fourdrive to work checked fuses they all good don't have power going ro actrator help me please
Is this electric switched check all wire connection there should be a switch two wire coming out on Transfer case around swift linkage that tell the truck what part of to use . I believe it is a type of pressure no pwr in 2 wd then too 4 hi or 4 lo power on check with voltage tester
Jun 01, 2014 | Cars & Trucks
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
Why is my Cub ZTR 50 keep braking belts? I only got 30 minute out of the last one at $40.00 a pop I can't keep going on.
check all the blade spindles for seized bearings. also check the pulley alignment, those issues can cause premature belt failure. Also proper tension can give you consistent long term use.
Dec 03, 2012 | Garden
Don't know how to use my Sperry outlet tester
http://www.sperryinstruments.com/documents/products/hst-401.pdf
Dec 15, 2009 | Sperry Instruments HST401 Voltage...
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
What is ZTR?
a ZTR mean Zero Turn Radius. Riding mowers are zero turn radius. Tracktors are not.
Aug 27, 2008 | Husqvarna 26hp 54" Ztr Tractor
Radio Communications Logo
70 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
