Shaky Picture only during Advertisement or... Mitsubishi SC 27403
I have a problem with my TV as far as a shaky picture whenever there is text on the screen such as a phone number for an advertisement or if I bring up the digital TV guide on the screen or anything along those lines. Even an old black and white TV show will make it shaky as well. I have had digital cable with the converter box for years and thought maybe the box was going bad? Or is it the TV itself? I thought I had found the solution with a bad cable end connection but that ended up not being the problem. My TV is a Mitsubishi SC27403
  • 74 Answers
If you have cable then put the cable wire directly in the TV, bypassing the cable box. If the pix is Ok it proves that the problem is the cable box. If the problem is still there then it proves the the TV needs parts inside.
Posted on Mar 24, 2008
Shaky picture once warms uphorizontal lines stream through it continuisly
there are some capacitors on the signal board that are associated with the pwer supply regulators off the 5 volt and other sources there that need to be replaced
if you have the tools and know how and soldering station you can do the repair your self if not then you might want to contact a servicer in your area
i can get you the cap location numbers if you like
Oct 24, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Shaky picture AKAI PDP4298ED1
THERE MAY BE SOME CONDENCER LEKAGE SOMEWHERE IN THE HORIZONTAL SECTION
Mar 23, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky/Unstable Picture
This is power supply issue, one or more of your filter capacitors either bursted and/Or over heats (this is why it becomes better when system cools down after turning it off for 1/2 hour..You have two choices.1. buy a replacement power supply may set you back a couple hundred dollars but it will be plug and play. 2nd you can replace these filter capacitors make sure the can handle 105 deg celsius not the 85 deg. celsius, if you know how to trace the bad ones and desolder and solder new ones on the power supply board, or hire a techinician to replace them for you. Good Luck...
Dec 14, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Shaky distorted picture first 5 minutes when tv turned on.
Those have a problem with the capacitors going bad in power supply. Yes, it's worth having checked out because a GOOD shop will be able to fix the problem and not have to change a board. Very common problem with these sets. Mine did the same thing until I fixed it. Just do your homework when finding a shop. Call around and talk to other people in the area to see who they use etc.. Good luck. Could be a very simple repair. Have it checked.
Dec 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Picture on email is unstable looks shaky.
if u have graphics card means jus remove it and connect it in the ordinary pin
Jul 03, 2008 | E-Machines eMachines Desktop PC
65 Inch Samsung Projection TV- Shaky Picture
have a tech look at your tv it needs to be repair checks can be made in the power supply.video circuit,or the IF CIRCUIT.good luck.
Apr 01, 2007 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
