Question about ASUS P5B Deluxe Motherboard
Change of serial number (BIOS, motherboard)?
Please, how can I change serial number?
I need to exactly identify each PC in my network. The serial number seems to be the best way (name of PC, IP address, data in registryDB - that everything can easily change).
I use WMI question "select identifyingNumber from Win32_ComputerSystemProduct" to get serial number of PC. Nearly every PCs of my network give mi their SN (there are hundreds of them) but there are two of them that five me string "System Serial Number". They both have ASUS motherboards with ASUS P5B-Deluxe ACPI BIOS Revision 1238.
I want to use SN as a primary key of my list of computers.
So the question is simple - how can I change serial number, please?
Thank you for your time.
Pavel Tajovský
pavel.tajovsky@uvoz.cz
  • 157 Answers
The serial number is encoded in the CMOS chip. You will have to see if ASUS provides a utility. ASUS is a great company and I am sure they will be able to asist you.
Posted on Apr 27, 2010
Acer serial number bt0060304294603b03b304
A serial number does not identify your computer to possably Acer. A model name and number is need to know what you need.
Here is a link to a Youtube search that will probably help.
acer battery change YouTube
Aug 19, 2014 | Computers & Internet
How to change from parallel to serial
if your PC has a serial port I'd think the motherboard should have a parallel port header on board. What you'd need to find would then (if my idea is right) just be a parallel port bracket for your computer (to be mounted at the back, in one of the plugin card spaces) which should come with a standardized connector to fit the header on the motherboard. After connection make sure that the parallel port is enabled in your BIOS
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 07, 2014 | IBM 6400 Office Equipment & Supplies
Can't get english
You can change the language settings
Click start control panel regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language.
also download language packs
http://windows.microsoft.com/en-US/windows/language-packs
Most BIOS versions included a language option
Get the computer manufacturer and your computer model number.
If it is available, go to the manufacturer site and look for BIOS & Firmware upgrades.
When your PC is starting up, press the Setup key.
This is usually Del, F2, or F12.
The key, however differs with each machine.
It should be stated on the screen for a very short time which key is the setup key
You can change the bios settings by using the ARROW KEYS select it press enter and exit then press the F10 key to save to cmos and restart
If your not sure or you have made any wrong bios changes you can set failsafe or optimised defaults
If you are unable to change the bios language settings the bios might need to be updated or bios chip might need to be changed or flashed
Before flashing the BIOS do a search on BIOS flash and read the caveats.
Backup your current BIOS and only flash if it is absolutely necessary!!
If the computer vendor is unknown or unavailable, try to identify the motherboard vendor and model number if you can, BIOS updates are specifically associated with motherboard versions:
Aug 05, 2013 | Computers & Internet
My bios setup language is change. so how to change english language?
When your PC is starting up, press the Setup key. This is usually Del, F2, or F12.
you can change the bios settings by using the ARROW KEYS select it press enter and exit then press the F10 key to save to cmos and restart
if your not sure or you have made any wrong bios changes you can set failsafe or optimised defaults
if you are unable to change the bios language settings the bios might need to be updated or bios chip might need to be changed or flashed
you can change the language settings
click start control panel regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language
hope this helps
Aug 11, 2012 | Mercury P4VM800M7 Motherboard
My pc have a following configuration:1 gb ram,npentium d processor, intel 945 original motherboard recently i change my 80 gb hard disk to 500gb new harddisk but pc get hang even if pc is clean formatted...
WOW- a really tough one... it sounds like a BIOS conflict.
My best advice is to go to the Intel website and check the known issues forum and see if the problem has been identified. It sounds like you are pretty good with computers and that did everything right, and that is why I suspect a BIOS problem with your particular configuration.
Intel is very good about putting updates out, so see if there is a BIOS upgrade for your motherboard. Be certain to follow the procedure EXACTLY if you need to "flash" your BIOS. It is critical that you back up your BIOS as specified, so if there are any problems, you can go back to your current configuration. Good Luck!
Jan 28, 2011 | Intel D945GCCR Motherboard
How can i identify my motherboard model
You can download Everest for a free evaluation. It will identify your motherboard and other components that make up your system
http://www.lavalys.com/products.php?ps=&page=11&dlid=35&lang=en
Please rate this solution. Thanks.
Apr 04, 2010 | Computers & Internet
Can i change my FUJITSU FMV6800 PC models graphics card?
Given that the BIOS reports "10/17/2000", it's time to REPLACE the motherboard, if you can find a motherboard that fits into your current case, and has the I/O connectors (keyboard/mouse/video) in the "correct" position.
Mar 26, 2010 | Computers & Internet
Sound card drivers on bord need AMIBIOS Motherboard Manufacturer Identification Version 1.4 (01/12/2004) Copyright 2003 American Megatrends, Inc. This file has recorded information useful in identifying...
look et...According to the numbers you provided you have Elitegroup Computer motherboard. So for any possible BIOS upgrade, drivers or any other technical support you will need to visit => www.ecsusa.com. or call them at 510-226-7333. Suc6 Theo.nl
Jan 07, 2009 | Computers & Internet
Want change my bios language
Dear Batoot ,
Let me know the Model number of your Gigabyet motherboard. Then i can provide you the Solution.It must Required the model No.
Cheerup
Mar 05, 2008 | IBM NetVista PC Desktop
IRQ
Can u be please clear about your problem. Why do you want to change the IRQ numbers .
You can go to BIOS and PCI/PNP configuration and change IRQ mode AUTO to Manual and assign how ever you like
Good Luck
Nov 21, 2007 | IBM Think Centre A50 P4 (841923u) Network...
ASUS P5B Deluxe Motherboard Logo
1,938 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
