Question about Hotpoint  Standard Range Hood
My aqurius WMF760 Hotpoint doesnt fill with water, we had this once before so i unpluged it from the mains waited 5 min then plugged it back in, this worked, same thing has happened again but trying the above has not worked, what to dit just over a year old so manufactures warranty is out
  • creagh_roger Apr 27, 2010
    NOPE ITS ONLY A COld water supply on there, and thats intact, so no extra bar pressure on there, somebody suggested a to fuse has gone on the water pump, or do a total reset....but how
    THIS is a washing machine, you sent me the manual.
    it is not a dishwasher???????????????........
  • 344 Answers
If the cycle won't start then I would say the door interlock is at fault, just pust the door and the cycle may commence. If you hear the water entering the machine it may be syphoning because the drain pipe isn't vented to allow air, Just make sure the drain pipe isn't taped up or sealed around where it enters the waste pipe. other than that you could have a faulty inlet valve
Posted on Apr 28, 2010
    President:
  • 1,851 Answers
Congratulations on owning one great dishwasher.
There are only a few things that can and do go wrong or wear down.
Please click HERE to see exact instructions set up just for this situation.
If this get's you going please rate my high and pass along a good comment.
Thank you for letting the FIxYa Team help.
Gary.
Posted on Apr 27, 2010
    Brigadier General:
  • 3,917 Answers
This sounds as a problem with the water supply connectors with the Hotpoint. Please check the page 8 of the instruction manual provided bellow to verify the connection:
http://dl.owneriq.net/d/def9566b-5c74-4e64-9cb0-317e24dcfce6.pdf
Please ignore the model as this basic connection is same in all Aqurius models.
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
Hotpoint WMF760 wont fill with water..spin cycle not working either
replace the water inlet valve under the top cover from the manufactures website quoting the model nr eric
Jan 18, 2018 | Hotpoint Washing Machines
Problem with a hotpoint wmf760 aquarius + error code h20 coming up
You may have soap & grease in the pipe that leads to the pressure switch. Remove and flush through and/or replace. dry before refitting.
Thus constant high would give pump faults (thinks machine still contains water). Constant low may cause over filling. If you have a plug that suddenly moves, that can cause the above errors.
Jan 02, 2013 | Hotpoint Ultima WF860 Front Load Washer
Help! no sound on my tv!
check all the leads and wires, especially the scart lead, and give them a little push, if this doesnt work (which it should) then unplug the tv from the mains, wait 5 mins, plug back in, wait another 5 mins, and turn on, if this still doesnt work, contact the customer service line of the company who made your tv
Mar 17, 2012 | Sharp Televison & Video
The sound on my TV has suddenly stopped working
check all wires are firmly in place, especially the scart lead, and just give them a little push to make sure, if that doesnt work, try unplugging your tv from the mains and wait 5 mins, plug it back in, wait another 5 mins, and turn on, if that doesnt work, contact the company's customer service line.
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Hotpoint wmd940k installed approx 2years, was saying no water, check supply now saying f 01 what does this mean?
F01: Aquarius and Ultima models may show this. It could be a faulty motor or motor control board. The motor tachometer could also be faulty. Some machines have a little rotating magnet and sensor, and the magnet can become detached.
I had the same problem with my Hotpoint WMD940P ultima washing machine. I got the engineer out and he replaced the main control board on my machine it might be the same for you. 1 thing to do is to turn machine off at plug for 5 mins then switch back on and if does it again that is properly it and you will need a engineer out to fix it. hope this helps.
it said check water because it properly did not fill cus of the fault to do with motor control.
Sep 19, 2010 | Hotpoint Washing Machines
Hotpoint  Standard Range Hood Logo
383 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
