Question about Lenovo IdeaPad S10 - 42312BU Notebook
My laptop dvd is not working . what may be the
My laptop dvd drive is not working . what may be the problems
  • Jose Cada
    Jose Cada May 11, 2010
    could you please clarifiy if the computer can detect the dvd drive. if you click on my computer the dvd rom drive is ussually specified inside this window. is it there?
  • frankdanfelt May 11, 2010
    Is it showing up under "My Computer"
  • 942 Answers
Hi grneelam, if your dvd is not working, it might not read the dvd.
Try this solution:
if using windows 7 or vista
click start > type run on the "start search" box and hit ENTER > type regedit
> click arrow in HKEY_LOCAL_MACHINE
> click arrow in System
> click arrow in Current_Control_Set
> click Control
> click Class
> click the folder 4D36E965-E325-11CE-BFC1-08002Be10318
on the right side of the registry, right click upper filters and click delete.
You will do likewise with lower filters.
Restart PC and test if DVD will work ...
Thanks
Posted on May 06, 2010
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
The DVD Drive on my philips freevents 12NB5800 isn't working. The problem is that the draw opens but the laptop isn't recognising the disc. I had tried going onto my computer and double clicking on the dvd...
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive
Aug 29, 2010 | Computers & Internet
Problem in cd-dvd drive of hp laptop
This is not a driver problem. It is almost certainly a problem with yourdvd/cd player. If it is reading dvd's, then it means that the driver is installed. You will have to take your laptop in and possibly get the cd/dvd player replaced.
Dec 09, 2008 | HP RT865UTABA - HP Promo dc5700 micro...
DVD drive reads DVDs but not CDs
Sep 28, 2008 | Computers & Internet
Laptop DVD /RW Drive
did you try a dvd cleaner some times the laser inside gets dirty and then it will not work if this does not work try a different dvd player in it a little serect is to try a different one always if still does not work might have to redownload the drivers for your computer on your computers website ..
Jul 14, 2008 | Computers & Internet
ACER ASPIRE 4315 DVD drive not recognised
See if your DVD drive is recognized when you boot. To get in the Bios, when logo appears during booting, hit "delete" or "F2" or whatever you are prompted.
Also, see that it is reconized without any marks in the Device Manager, once you boot OS.
Jun 01, 2008 | Computers & Internet
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
DVD Disc in my Toshiba Laptop Corrupted
make uninstall driver for CDW/DVD then re-boot.
Install the driver for CDW/DVD and use. It will fix your problem.
Thanks
Iqbal
Apr 13, 2008 | Computers & Internet
Dvd drive
its u r dvd drive laser eye problem.replace u r dvd drive
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Laptop DVD/RW Drive
Hi takino, Sounds like you have a faulty connection between your drive and the laptop or you drive has some serious problems. The first thing to try is reseating your DVD drive as follows: -Flip the laptop over with the front of the laptop facing you. -The DVD drive should be on you right. Towards the right center there is a single screw that secures the DVD drive to the laptop, remove it. -Insert a straightened paper clip into the release hole just underneath the DVD eject button on the DVD tray front. The DVD tray should eject. - Use the DVD tray to pull the DVD drive out of the laptop. It shouldn?t take too much force, but it might be snug. -Pull the drive out and look inside the bay. Clean any dust or foreign material in it or around the DVD connector in the bay or the drive itself. -Reinsert the drive and replace the screw. -Start the laptop and test. If that doesn?t work I would suspect your drive is probably damaged. If you are lucky and know someone with an identical unit you can swap drives and see if the problem follows the drive or stays with the laptop. If the problem stays with the laptop you probably have a motherboard problem, if it goes with the drive then you have a bad drive. Replacement drives can usually be purchased relatively inexpensively on Ebay or other parts supply houses. Motherboards, however, tend to be more expensive and are far more complex to replace. Let us know if you have another questions and please don?t forget to rate the posting.
Jan 14, 2007 | HP Compaq Presario R4000 Notebook
Lenovo IdeaPad S10 - 42312BU Notebook Logo
26 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
