Router I am not able to open the setup page of the linksys router
    Brigadier General:
  • 6,966 Answers
The setup page for a LinkSys Router is normally accessed using a browser addressed to 192.168.1.1. If for some reason "Page can not be displayed or Connection has timed out" shows up, perhaps the reason is that the PC is not on the same network as that of the router.
A couple of things you can try:
1. Run the PC to the router using LAN cable and not WiFi;
2. In your Network Connections (Control Panel), right click on your Local Area Connection, click on Properties, highlight Internet Protocol (TCP/IP) and click on the Properties button.
3. In the next pop-up window, tick "Use the following IP address". IP address - 192.168.1.2, Subnet mask - 255.255.255.0 and Default gateway - 192.168.1.1, OK, OK.
4. Make sure to check "Show icon notification..."
5. In the Networking icon in the System Tray, right click and click on Repair.
6. Try your browser now on 192.168.1.1.
If your concern has not been corrected after completion of the above procedures, possibilities are:
i. your PC's LAN card is at fault (hardware or drivers);
ii. the LAN cable would require replacement;
iii. the LinkSys router is at fault.
A sure way to verify network connectivity between router and LAN card/PC is when properly connected, the router's led display for that particular Ethernet port will light up and/or blink.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 24, 2008
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
Check settings of router
What do you want to check?
You want to check the wireless settings of the router?
For this you will need to connect one computer to the rotuer and open the setup page.
Open Internet browser and in the address bar type 192.168.1.1.
It will prompt you for the Linksys router password.
Once you open the setup page you will find all the settings of the router
See How to check the settings of the router
Jan 22, 2012 | Linksys Wireless-G WRT54G Router
I get an error 323 during setup
Are you trying to run the CD to setup your router?
I will suggest you to install your router manually.
It is very easy.
Connect one computer to the router. Open the setup page of the router and change the settings manually.
See Linksys router setup.
Jan 09, 2012 | Linksys WRT54G2 Wireless Router
Where to download the installation disk
Are you trying to setup router?
You can install your router manually.
You don't even need to run the CD>
Just open the setup page of the router and change the Internet connection settings manually.
Jan 07, 2012 | Linksys Wireless-G WRT54G Router
Diagram to hook up wireless router
You can do it manually without CD.
Connect the modem to the Internet port on Linksys router. The connect one computer to Ethernet port 1 on Linksys router.
Jan 02, 2012 | Linksys Wireless-G Broadband Router
Where can i download a free installer for linksys wifi router with model # wrt120n
Are you trying to install WRT120N router?
Connect the computer to the router. open the setup page and change the settings manually.
See how to setup Linksys WRT120N router
Oct 13, 2011 | Linksys WRT120N Router
Have a netbook how to install linksys router wrt120n
Are you trying to install Linksys router?
You don't need to run the CD.
You can do it manually.
Connect your netbook to the router and open the setup page of the router.
Change the settings manually and you are done.
Oct 03, 2011 | Linksys WRT120N Router
It has password and I can't open it
Resetting the Linksys Router to Factory Default
To reset the router to its default settings, press and hold the Reset button located at the back of the router for 10 seconds.
IMPORTANT: Older Linksys devices may require pressing and holding the Reset button for 30 seconds to complete the reset process.
kb19584-003_en.png To perform hard reset on your Linksys router, follow the steps below:
NOTE: The location of the Reset button may vary for every model.
If the normal reset does not work, unplug and re-plug the router's power adapter while pressing the Reset button.
You can also reset the router via its web-based setup page. Follow the steps below to learn how.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click the Administration tab then click on the Factory Defaults sub-tab.
kb19584-004_en.png NOTE: If the screen on your router's web-based setup page is different, click here.
Step 3:
Under the Factory Defaults section, click on the Restore Factory Defaults button.
kb19584-005_en.png The default settings of your router are now restored.
Sep 20, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
How to setup linksys router
You can setup Linksys router without installation CD or software.
Connect the computer to the router and open the setup page of the router.
Change the Internet and wireless settings manually.
I will suggest you a website on How to setup Linksys wireless router.
This website may help you installing your router
May 28, 2010 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
319 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
