Question about Canon BubbleJet i560 InkJet Printer
Not printing anything. The paper goes through the printer (slowly) and comes out blank. All the cartridges are full and appear to correctly inserted in their correct positions.
  • 493 Answers
1- First, would you please install the latest printer driver using the link here. Select your operating system in the opened web page. And under the drivers headline below it, click on the ".exe" file to download the printer driver. Download and install that driver.
2- If it still doesn't work, please clean the printer heads of the printer using the manual descriptions in the picture below:
3- If it doesn't work you can hold your cartridge heads above the cattle vapors. It should resolve the stuck ink on the cartridge. Replace the cartridge back and try printing.
Hope this helps. Regards.
Posted on Apr 27, 2010
Panasonic printer kx mb 262 driver download
Iakjanila, remove the toner cartridge slowly. 2. Tilt the cartridge back and forth to ensure even distribution. Do this slowly. 3. insert it again in the printer, close the compartment cover and now test print. GL
Jan 12, 2014 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Changed black cartridge now paper goes through printer but is blank. cartridge instaled properly.
Print a demo sheet.
1. Verify that inkjet paper is loaded in the paper tray.
2. Press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes green.
Does a blank print appear? If so:
How did the paper exit your printer?
Quickly and smoothly
Slowly and in increments
If quickly and smoothly, contact Kodak at 1-800-421-6699.
To expedite the call, provide the agent with the one of the following reference IDs - PH02 for image quality problems or BP01 for problems with blank prints.
If slowly and in increments, reference BP02
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Blank paper
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Paper goes through the printer as though printing but paper comes out blank
Just make sure the cartridges are not running out of ink. Try with different carts, It should work fine.
Apr 20, 2008 | Office Equipment & Supplies
No ink coming from cartridges.
Seems like a lot of people are all of a sudden having these problems. I have had this printer for 4 years I think and no problems at all. Phone support says to clean the heads 3 times and then they give up. By the way, there is no tape to remove from authentic ink cartridges for this printer. The cartridge holder pops a hole in the film. You cant pull that cover off, it is popped when inserted.
Jan 28, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
42 people viewed this question
old marine
old marine
