Question about PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote
I have a 7' lcd screen for i-disply only input is memory card but card missing how i use another card w/o software because any other card inseting time it shows loding after again insert memory card please help me oif you have any software for that
    Guru:
  • 513 Answers
You buy a memory card for the picture frame, they don't come with one. You need to use your computer to load the memory card. If you have the CORRECT card, please format the card to clear off any data. Load pictures of any common type like .jpg or .bmp or .gif. There should be no software required to use the frame.
The frame may require you to use a folder on the card. See your owner's manual.
Your card may not be working. Use a computer card reader to test and load the memory card.
Posted on Apr 28, 2010
I have lcd syncmaster 740nw of samsung, right side of screen five or six cm screen not disply.
Check your video connection, however I am positive that your lcd panel is broken. You can get cheap replacement lcd panels on Ebay or you can search Google shopping for them as well.
May 06, 2011 | Samsung SyncMaster 740NW
Only power on in lcd.no disply and etc
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Jun 14, 2010 | IBM ThinkPad T30 2366 Notebook
Changed out power supply, now can't get video to work
pls ckh ur power supply 5v 12v again other wise change power supply.
pls, chk it is at,or atx power supply.
or ur mother disply ic is damage
inset new display card.
Feb 23, 2010 | Intel ASUS P4S800-MX SiS661FX Motherboard...
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
Only half of sreen lights up and is frozen. Do all 350 have a memory card? When my husband brought it in from his last trip, there appears to be no memory card in it. Could this be my problem with only...
Stock Nuvi's from the factory do not include a memory card (SD card). You do not need a memory card to operate the Nuvi. The memory card is only needed if you want to add more storage space for music or pictures or if you want to add additional maps. It has nothing to do with the LCD display. Having worked on these units for quite sometime, anytime you have 1/2 of the screen missing, it tells me that your LCD display is defective.
- Jim
SHARCNET-USA
Dec 03, 2008 | Garmin nuvi 350 GPS Receiver
Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Nov 23, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Error on my memory card
To be honest I think your memory card has had its day and I could only suggest that you buy a genuine memory card from a trusted seller ie a local camera store or a large supermarket.
I know that the above seams harsh but I too have struggled with cheap sd cards when an a more expensive one will give far more service.
Mar 28, 2017 | TwinMOS Technologies MP3 USB S21 256 Mb...
PANDIGITAL PAN 70-0 7.0" LCD Digital Picture Frame With Remote Logo
121 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
