Question about Magnum DeltaForce CB Radio
My backlights are not working cant see channels at night .
Can some one show me diagram on where the 12 volts 6volts . can be crossed at
    Champion:
  • 219 Answers
The easy way is for you to get a meter find a good ground, where the coax enters in the back would be a good spot and locate one on your own instand of someone telling you and you miss understand and do harm upon your radio.
Posted on May 08, 2010
Why is my Remote showing relay fault
315Mhz remote relay switch kits - 2 channels - Seeed Studio
www.seeedstudio.com/.../315Mhz-remote-relay-switch-kits-2-channels-p...
This remote switch allows you to remotely control any 12 Volt DC device. ... to supply 3-5VDC to the "+12V" pin,(Caution: the 12v is an error silk screen on PCB, ... Is there a wiring diagram to show how you connect the sender to the GPIO pins?
Amazon.com: 1 Channel Wireless Controller (On/Off) 12V ...
www.amazon.com > ... > Lighting Accessories
Amazon.com, Inc.I wired this remote relay to a fuse block below the motorhome frame. ... Here's a (very) short video showing how the remote control works. I love it! It's very easy to ...
12v wireless 315 MHz remote control relay board 6-channel ...
? 4:36
https://www.youtube.com/watch?v=JBzL0MIno2w
Feb 2, 2013 - Uploaded by Julian Ilett
12v wireless 315 MHz remote control relay board 6-channel ... The relay board takes 12 volts in and there ...
Dec 03, 2015 | Cars & Trucks
Dead set
Check for blown fuse EP91. If the fuse is blown, check for a shorted IP01 regulator transistor in the deflection power supply. If that is shorted, change the IP04 photo coupler and leaky D05 a 12 volt zener in the OCP circuit of IP01. If this all looks good, look for an oily fluid on the printed circuit boards under the picture tubes. Good Luck
Jun 21, 2007 | Hitachi 43FDX01B TV
IS THE 1951 Packard POS GROUND OR NEG AND IS T A 6 VOLT SYSTEM?
51`s were positive ground and 6 volts. count the battery caps. if there is 3 caps its 6volts, if there is 6 caps its 12 volts. sometimes if its not original someone may have converted it 12 volts.
Sep 07, 2015 | Packard Cars & Trucks
A 4 ton Kia truck what voltage is the battery
Count the holes on the top of the battery to add water. Each one = 2 volts so if you have 3 x2=6volts 6x2 = 12 volts
Oct 01, 2014 | Cars & Trucks
The auto mode isn't working on my zilla digital 24-7 power center, when on auto mode no lights come on?
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Is this a new timer??? Or old timer that stopped working?
Replace battery.
Press reset button to clear all memory traces before programming.
Check programming for overlaps and mismatched day(s) of operation.
Test outlet for correct polarity and grounding using circuit analyzer.
Make sure light bulb is turned ON. Timers do not reach out and rotate on-off switch.
Make sure outlet has at least 80% rated voltage shown on load label. For example 115 volts x 80% = 92 volts
About your specific programming needs:
Zilla selects 12 o'clock as changeover time between am-pm.
So if you want 8:02 to 7:59 operation, then that is under the 12 hours, but it crosses the 12 o'clock am-pm changeover.
Workaround: Shorten your times to less than 12 hours just like you have done.
But set current time differently so 8-8 falls under either am or pm, but does not cross am-pm. The timer does not actually know what the current time is, so simply fudge by amount needed.
Nov 18, 2012 | RTO Zilla 24/7 Digital Timer Power Center
My backlights are not working cant see channels at night . and have replaced all 6 little lights
There is a small voltage regulator on the board that the lights mount on, behind the faceplate. It's probably bad. You can isolate the voltage supply on that board and run 12 volts to those traces. You'll need to do some reconfiguring to keep the 6 volt bulbs but you can forget about the bad regulator when you do that. Be very caeful to ISOLATE THE TRACES From ANY Other Traces. If you foul up, Poof!
Apr 11, 2010 | Magnum DeltaForce CB Radio
The backlight on Receiver RX-460 does not light up
no fuse need lamp replaced-usually 12 volts and avail from radio shack if you want to replace it yourself.
Feb 27, 2010 | Audio Players & Recorders
Voltage of the backlight on the Kenwood TS-60 Need to replace the backlight on the Kenwood TS-60 Transceiver radio. Need bulb voltage, type or number. Any specifics would be helpful
check voltage of existing wire leads....any 12 volt wheat lamp will do or use resistor with 6 volt....copper electronics carries 12 volt grain of wheat replacements for .49
Jan 25, 2010 | Radio Communications
No dome light on tacoma
The dome light gets 12 volt battery power at all times. The door switch, when the door is opened, allows the current to flow to ground, and completes the circuit. The door switch allows the ground to be made. Measure for 12 volts at the wiring connector, and measure for direct short at the ground wire, with the door open. The Ground wire is white with a black tracer.
Feb 26, 2009 | 2004 Toyota Tacoma
Radio Communications Logo
71 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
