Question about HP OfficeJet 6210 All-In-One InkJet Printer
How doi replace a lamp in hp projector?
Lamp
  • 4,041 Answers
Hi there
It not easy I would take to shop.
Posted on Apr 27, 2010
Tip
Replace HP VP6321 Projector Lamp Models: HP VP6321 / HP VP6320 / HP VP6310 / HP...
Models: HP VP6321 / HP VP6320 / HP VP6310 / HP VP6300
Here are the steps to replace an HP VP6321 Projector Lamp:
  1. Turn off the projector and allow it to cool for 30 minutes.
  2. Unplug the power cord.
  3. Press the release latch (1) on the lamp cover and remove the cover (2).
  4. Press the release latch on the lamp connector and unplug the connector (3).
5. Loosen the two screws (4) on the lamp module, and pull out the module (5).
6. Insert the new lamp module into the projector and tighten the two screws.
7. Plug in the lamp connector.
8. Snap the lamp cover into place.
9. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp.
10. On the projector, press Enter.
11. Advanced setup, then Reset lamp hours.
12. Press Enter.
The lamp module has now been replaced and the projector is ready for use.
I hope that helps.
________________________________
Download Hp VP6321 Manual here.
on Apr 23, 2010 | HP vp6320 Multimedia Projector
Dull image on projector
This is an old projector which was released in May 2005. Projector image degrades over time as the lamp dims, and other internal factors affect brightness. The original rating is 1600 lumens which is not bright compared to a modern projector.
You can check to status which may give you lamp information by pressing ENTER on remote or projector and going to HELP.
You may find that replacing the lamp helps, however older lamps are expensive and could replace the whole projector with new one of higher specification, complete with 3 year warranty if you spend double as much. A new lamp will not restore a projector to its new state either. Here's a link to the lamp (for the UK), it's over £200 + VAT + delivery, and that's not even for a genuien HP lamp
http://www.every-projector-lamp.co.uk/projector-lamps.php?&brand=HEWLETT+PACKARD&model=VP6310
As I say, you can get projectors with a better spec for as little as £372 + vat + delivery. This one is similar to yours, in that it is a 4x3 business projector. It has an XGA resolution. (Yours is VGA). It is 2000 lumen brightness and it has a 3 year warranty.
http://www.ivojo.co.uk/projector-spec.php?pid=Samsung_SP-L201
Hope this helps...
Feb 21, 2011 | HP VP6310 Multimedia Projector
New lamp fitted to a 6121 uint but it says replace lamp as life has reached more than 2000 hours
Follow the procedure in the manual, as this counter needs resetting too. There may be a reset button near the lamp or cover.
Sep 02, 2010 | HP VP6121 Multimedia Projector
No display from projector
try resetting the lamp timer. if that doesn't work: listen for a high pitched whir when you power it on. if you don't hear it, the colorwheel needs replacing. if you do hear it and it doesn't light, the ballast is bad and needs replacing.
Aug 10, 2009 | HP Digital Projector Vp6110 Multimedia...
Hp projector vp6111
Go into the menu and find the lamp timer. You should then be able to reset the timer back to zero.
Nov 19, 2008 | HP VP6121 Multimedia Projector
HP sb21 lamp
There is a very picky sensor on the lamp cover. When the lamp and cover are seated perfectly, your lamp will start.
Apr 07, 2008 | HP Digital Projector sb21 Multimedia...
Hp projector
This is caused by the color wheel sensor failure. The sensor is mounted very near the lamp and suffered extreme temperature. This problem can be corrected by installing the redesigned color wheel sensor. You also need to refocus the sensor due to different focal length. HP also recommended to replace the temp sensor cable. If you still have the projector, I can fix the problem for you.
Jan 08, 2008 | HP vp6320 Multimedia Projector
HP vp 6120 Projector
Hi there
Have you reset the lamp timer ?
If you have and the problem stil occurs you will have to replace the Ballast ( lamp's powersupply ) This is a very common problem with this specific HP model.
Dec 29, 2007 | HP Digital Projector Vp6120 Multimedia...
Change the lamp/ didnt help, lamp indicator is on
I actually fixed this myself!!!! Same thing, new bulb, fans work, turn on for first 20 seconds or so, see HP splash screen and then it shuts down. Try below....It worked for me.
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jack-
Nov 12, 2007 | HP Digital Projector Vp6120 Multimedia...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
