Question about Sony Ericsson w580i Cellular Phone
Applications are not opening, just shows a locked key signs on them, when opening get error of "Operation field"
  • suahmadi Apr 27, 2010
    before it was working applications are all .jar but when i run a new application that was also .jar one, suddenly all installed applications get locked as i mentioned
  • 713 Answers
Hi,its obvious from your problem that the applications you are trying to access on your phone are of a formatnot supported by your phone,only java based applications are supported by the w580i because it's a java enabled phone,other application formats won't run on the phone.
However,you can get java appllications for your phone at www.getjar.com all for free.
Thanks and take care
Posted on Apr 27, 2010
2006 ford 3.9L has code P0625, but my alternator is charging just fine.
P0625 - Generator Field Terminal Circuit Low Description: The powertrain control module (PCM) monitors generator load from the generator/regulator in the form of frequency. The concern indicates the input is lower than the load should be in normal operation. The load input could be low when no generator output exists. Possible Causes:
  • GENRC circuit short to ground
  • GENLI circuit short to ground
  • Open B+ wire during operation
  • Low system voltage
  • Broken generator belt
  • Damaged generator/regulator assembly
Diagnostic Aids: Verify the battery voltage is 14.5 volts. Verify the generator/regulator has the correct part number. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test HY .
Dec 21, 2016 | Ford Cars & Trucks
Sc997
Application function selection error
The application selected by a key press
on operation panel does not start or
ends abnormally.
• Download the firmware for the
application that failed
• An option required by the application
(RAM, DIMM, board) is not installed
Re-seat the RAM on the controller board
Mar 28, 2013 | Ricoh Aficio 2027 All-In-One Laser Printer
Error 19
Hi
You can try the following steps to resolve the Code 19 issue.
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Jul 16, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
I am using nokia 7210 supernova . When i am opening musicplayer it showing operation failed error and not playing. How can i resolve this problem i updated my mobile software also.
May 20, 2010 | Nokia 7210
Sony ericsson Handset showing ''Operation failed error''
This error occurs when your phone is checking the signature of a digitally signed java application and there is no match or is unable to do so. The most common cause is that the signature is expired. Try setting the date backwards on your phone - let's say one or two month :-) and have a look! I bet it works now....
Mar 21, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Unable to update my protection after uploading new 2009 Micro Trend Internet Security package using a 64-bit operating system. Error message advises to check my proxy settings. I've done that. System is...
this is the resolution i got from trend micro regarding this error. it worked for me, so i thought i should share: I have reviewed your case and I understand that you are getting an error message that says “Unable To Update Your Protection” when updating the Trend Micro Consumer Product. With regard to your concern, this problem happens if there’s a missing component in your computer’s Registry. Let us configure the registry of your computer using the Registry Editor of Windows. Refer to the following. 1. Click on the Start button or the Windows Orb Button. 2. Windows XP: Click on Run then type regedit on the text field then click on the OK button. Windows Vista: Type regedit on the Start Search above the Windows Orb button then press Enter key on your keyboard. And the Registry Editor window will appear. 3. Click on the plus sign (+) or the arrow sign (>) besides HKEY_LOCAL_MACHINE. 4. Click on the plus sign (+) or the arrow sign (>) besides SOFTWARE. 5. Click on the plus sign (+) or the arrow sign (>) besides Microsoft. 6. Click on the plus sign (+) or the arrow sign (>) besides Windows. 7. Click on the plus sign (+) or the arrow sign (>) besides CurrentVersion. 8. Click on the plus sign (+) or the arrow sign (>) besides Explorer. 9. Click on the Shell Folders. 10. Look for the Common Appdata entry on the right panel. If there’s a Common Appdata entry on the list: - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. If there’s no Common Appdata entry on the list: - Right click on an empty space and options will appear. - Click on New and options will appear. - Click on the String Value option. - Set the name to Common Appdata. - Double click on the Common Appdata entry and the Edit String window will appear. - Windows XP: Type C:\Documents and Settings\All Users\Application Data on the text field under Value Data. Windows Vista: Type c:\ProgramData on the text field under Value Data. - Click on the OK button. 11. Close the Registry Editor window. 12. Restart the computer for the changes to take effect. After doing the suggested solutions, you should now be able to update the program successfully.
Jan 22, 2009 | Computers & Internet
Problem in games & applications
unable to open games and applications folder.- error is showing = "operation failed " kindly help
May 07, 2008 | Sony Ericsson K550i Cellular Phone
Operation failed
every time i try to open the games folder it allways sayss operation failed how do i fix this
Feb 22, 2008 | Sony Ericsson K550i Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
55 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
