NAD 501 CD player reading error
The laser initiates but the CD won't spin. Isuspect a spindle motor has failed. How do I test or replace spindle motor on this model? How do I match the right clearance from laser? Is miguelovitch website online? I tried to access http://www.miguelovitch.dk but no success. Please help.
  • 1,512 Answers
There are a few ways to determine a lazy spindle motor.
  • listen to it. If it sounds like a diesel engine, with regular knocking sounds, bearings are failing... new motor
  • sit the unit on its side, see if it then reads...if bearings are worn, this reduces "slop"in the motor that can contribute jitter to the RF waveform. If it plays then,new motor
  • put a drop of oil into the top bearing of the motor. If it starts to read and run ok, then the bearing may be tight, and need lube, or the oil is acting as a hydraulic bearing. It will not fix the problem if it is a worn bearing. ...new motor.
  • if it spins up slow, and with screeching noise, the bearings are tight. see below for a solution.
Some other solutions.,
  • disconnect the connections to the motor remove a top mounting screw from the motor, and use a straw to flood the motor with crc 2-26, and spin up for 5 minutes one direction at 12 volts, then the other direction. Cleans the armature and brushes.
I always use a steel ruler to measure the height of the platter to the deck of the transport. then set the spindle height for the new motor up to the same as I measured. Happy to answer and questions that you may have. I have repaired literally hundreds of cd players over the years... including many NADs Cant recall just what the 501 has. But spindle motors cause a lot of problems with cd players.
regards robotek
Posted on Apr 27, 2010
  • Graeme Ross
    Graeme Ross Apr 27, 2010
    My memory is returning somewhat... this unit uses a Philips transport, and you will find that the spindle platter is bonded to the spindle motor shaft, and you may have some problems replacing it. or even removing the spindle platter... It was always replaced as a complete unit. Laser and spindle motor complete as an assembly.
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
Panasonic Portable dvd/cd player model #DVD-LS90 The player turns on and tries to read the DVD. However, it no longer spins so the DVD cannot be read.
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Panasonic Televison & Video
When i put a cd in the cdj it won't read it and ejects it
This is more than likely a laser issue. Does it spin the disc up? The first thing the CDJ will do when you put a disc in, is look for a reflection of the laser, which tells it that there is a disc inserted. There should be a short pause whilst it does this, before it fails and spits the disc back out again. If this is the case, there is either dirt and grime on the laser lens, or the laser needs to be replaced. Normally I recommend replacing the traverse mechanism, which includes the spindle motor and laser assembly.
If this needs to be replaced, either ask for more help, or contact your local Pioneer Service Agent.
Hope this helps :)
Jaye
Oct 27, 2011 | Pioneer CDJ-1000 CD Player
When trying to play a dvd , it shows H07
Traverse unit (spindle motor & laser assembly combined) is most likely faulty. The motor part usually fails first, which stops the discs from spinning, so the inbuilt laser cannot read them, hence the error code. This can be expensive to replace.
Jan 28, 2011 | Panasonic DVD-RV32 DVD Player
I have nad c541i,for last few days,it not reading the cd,as the disc goes in,there's a bit sound from the spindle which goes off after 5 secs,but doesn't read the disc,the screen keeps flashing like --...
this has the sony mechanism so if you take the lid off and unscrew the 2 screws, 1 at either end of the cd clamp and remove it, you should see part of a large cog just under the front of the cd tray, try turn this clockwise and the tray should open.
once open, you should be able to see a small plastic cover, loosen this slightly and replace the belt as this is prone to slipping on this mechanism stopping it clamping the disc properly when closed.
the sound you say is the spindle motor, is actually the loading motor trying to lift the whole laser mechanism up towards the puck to clamp the disc as there is not enough tension left in the belt.
help it along by hand and you'll see what i mean.
hope this helps?
Nov 21, 2009 | NAD C521 CD Player
My NAD C251i CD player isn't reading disks - platform stops short
To fix it, you need to replace the spindle motor top bearing. The bearing is worn and the player mistracks as the armature moves about under the changing drive conditions. Makes the player mistrack and skip. Because the disc is spinning fast.
Replacing the bearing should resolves the problem.
Hope this helps and have a great day!
Sep 01, 2009 | NAD C521 CD Player
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
1,210 people viewed this question
 Grubhead
Grubhead
