Question about HP Pavilion F1703 17" LCD Monitor
HP F1703 Screen goes black within seconds of startup
The screen initially displays an image (dull) on startup, but goes black within seconds. Powering the monitor off and then on has the same result, initial image then black.
  • HP Master
  • 1,606 Answers
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Posted on Apr 27, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
LG flatron w2230s-pf monitor only displays for 3 seconds, then the screen goes black. power is still on, and you can very faintly see the image. if you turn it off and on again, it will display correctly...
The problem is in the inverter board, the most common problem is bad capacitors, inverter transformers, or back light issues. The power supply and inverter share the same board, attempts can be made to repair or replace the board, if a professional gets involved you are further ahead in buying new.
Apr 21, 2011 | LG 22" FLATRON LCD Monitor
My monitor, hp w2007, shows for about 20 seconds when turned on then goes blurry then black how do i fix???
The most common problem that causes the screen to go to a black screen is due to bad capacitors in the screen's power supply board. The bad caps are the cylindrical and will appear to have bulging tops. 66c561df-0d01-416a-ae23-71f3b3965c88.jpg
Oct 24, 2010 | HP W2007 LCD Monitor
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
The hp f1703 will display for 3-5 seconds and go balck
rking3905, Please tell me if F1703 is BOTH BLACK and BLANK, or if it is just BLACK! If the screen is BLACK and you can see the WIN-desktop with aid of flashlight held 1" from the screen then the monitor's "switch-mode-power-supply" is in partial shutdown mode having detected a FAULT condition with the "cold-cathode-fluorescent-lamp" power supply called an INVERTER circuit (12vdc to 600-1200vac) to light-up the lamps hung on the rear of the LCD panel which produce WHITE light so you can see the image or text displayed on the LCD glass panel. In any case, you or a technician will need to evaluate the true state of your monitor. Also try to view some video clips on YOUTUBE that deal with "LCD monitor disassembly" and "LCD monitor repair". The longer (8-12min) clips are best. FYI goto www.ccl-la.com/badcaps, www.lcdparts.com, www.badcaps.net for more information on what may be the cause of your BLACK and or BLANK screen! If this was of some help, please rate this response on fixya.
12fixlouie
Nov 05, 2009 | HP Pavilion F1703 17" LCD Monitor
I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Oct 18, 2009 | Computers & Internet
HP Pavilion F1703 17" LCD Monitor Logo
293 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
