Question about Skullduggery Krazy Kars Ford F150 Model Kit
No power 2 elect windows on ford ka - Skullduggery Krazy Kars Ford F150 Model Kit
  • 4,869 Answers
Check
1....Fuse
2...Visually check the wiring loom between the car body and door to make sure there are no wires broken
Posted on Apr 29, 2010
Electric Windows on ford ka don't work, they used to then got progressively worse to stop completely
Before concluding the motors have weakened, use a child's toothbrush to thoroughly clean the window channels. You may have to repeat periodically. Do not lubricate the channels.
Aug 15, 2016 | 2007 Ford Ka 1.3
How can i convert my ford Ka power steering to manual steering?
this would be a costly exercise , more than the car is worth ,what are the probs with the power steering?
Apr 24, 2014 | Ford Ka Cars & Trucks
Ford KA 1996 CD player displays "error 2"
take it to a ford dealer or replace it with a used unit -cheers Denny
Jun 04, 2013 | Vehicle Parts & Accessories
Location fuse for electric windows ka
For all types of power window problem and power windows not working,i suggest you to go through the help links given below. Click the link to go through its procedure to troubleshoot the problem :------
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Power windows not working after car wash?http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
-----------This will help.Thanks
Feb 11, 2012 | 2001 Ford Ka
Hi, i need to put water in my Ford Ka because the light is flashing and havent done it for a while. There are three tanks under the bonnet, one says power steering fluid so i assume its not that one. Then...
Hi, I'm not familiar with the Ka,but did the light go out after adding water? There are only 2 car fluids that are red. One is auto transmission fluid and one is a type of coolant. The transmission reservoir is in the pan, so I doubt you could have seen red fluid in the transmission without pulling up the dipstick. You can also try disconnecting the level sensor on the reservoir that you added water to. If the coolant light goes on and off when you short the terminals in that connector together (use a paper clip), then that is the coolant reservoir. My guess is you got it right.
Jan 01, 2011 | Ford Fiesta Cars & Trucks
My ford ka has lost power when going up hills and over 60mph
was it a second hand motor or reco one if it was a second hand motor then you may have a blown head gaskit
Aug 25, 2009 | Ford Focus Cars & Trucks
Cant find temperature gage on v reg ford ka how do i know when its getting to hot, surely once the lights come on its to late, ON YOUR CATAEGORY YOU DONT APPEAR TO HAVE KA 2, SO TO GO ON I HAVE CHOOSEN...
The light will come on when the motor reaches a certain point, most of the time this point is a point of get to the nearest station and get it checked
Jul 05, 2009 | 1999 Ford Taurus
My ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
Jan 07, 2009 | Car Audio & Video
Ford ka window switches not working
Check for loose wiring connections behind the door panel on the offending side.
Nov 27, 2008 | 2007 Ford Edge SEL Plus
Skullduggery Krazy Kars Ford F150 Model Kit Logo
127 people viewed this question
Top Skullduggery Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Skullduggery Toy Expert? Answer questions, earn points and help others
