Question about Acer Aspire 5100 Notebook
How can i allocate more memory to video card of acer aspire 5100
Im using acer aspire 5100, with shared video card memory of 128mb and i have a 1Gb ram, i tried to changed it in bios but the maximum value for video card memory allocation is 128mb,how can i change my video card memory to 256mb?
  • 615 Answers
You can only do that with onboard video cards. If you have an onboard you can choose how much ram to assign to it in your bios settings. However it is limited and if you already have 128 assigned to it, that's probably about all it's gonna give ya. But hey it never hurts to check Assigning your physical memory to your graphics card will result a shortage of your total system memory and your whole system will slow down a bit.
Video cards meant for better processing the graphical content of your system and free up your system's physical memory.[via]
So, if you buy a new and better video card with more memory you will have a fast system with better performance.
Posted on Apr 27, 2010
    Novelist:
  • 151 Answers
Hello quid1103
If the maximum video card memory allocation is 128MB, you can't do anything to change it.
Laptops as a rule can't have their GPU (Graphics Processing Unit / video card) upgraded. If you want to play more demanding games, video editing, etc., you may have to consider buying a newer laptop. I recommend buying one with a dedicated GPU, the higher RAM, the better!
The better alternative is to buy a desktop PC, where you can upgrade the GPU when needed.
Hope this helps
ajblaj
  • Acer Master
  • 1,606 Answers
You can't. The limit is in your bios so to change it to 256 you would have to change the bios. They do bios updates all the time but I have never heard of them changing the shared ram limit.
Need abetter graphic card for acer aspire 5251
in Acer Aspire Series is using Intergrated Graphic Card.
that mean if you wanna Upgrade your Graphic Resolution,
you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
But in My Computer Properties the RAM will Show only 1Gb.
Because another 1Gb of RAM you've use for VGA.
you can check it from dxdiag.
(for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
Jan 07, 2012 | Acer Computers & Internet
I'm having a problem with HP DC7900 SFF. The Video Card shared memory is 1GB. according to there technical paper maximum should be 384MB only. I'm using winxp sp3 with 2GB memory. How can i change...
The amount of allocated shared video memory is configured in the BIOS configuration.
Go into the BIOS - video memory to change the amount of video RAM..
Jun 20, 2011 | HP Compaq DC7900 PC Desktop
The amount of allocated shared video memory is configured in the BIOS configuration - video memory.
Jun 20, 2011 | HP Compaq DC7900 Small Form Factor PC...
I want to upgrade the graphics card on my acer aspire m3400 but can not locate the card on the motherboard
That's because the video is integrated into the motherboard. This PC supports HDMI... what exactly are you trying to 'upgrade'? If the on-board video is not performing as you want, from what you can see here, you may only need to upgrade RAM on your MB:
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM3400/AspireM3400sp2.shtml
#4 at the bottom of the page:
Shared system memory may be allocated to support integrated graphics, depending on system memory size and other factors. Actual system memory available to the operating system will be reduced by the amount of dedicated and shared system memory utilized by the graphics solution and resources required by the operating environment.
Jan 05, 2011 | Acer Aspire M3400 PC Desktop
Can i upgrade my graphics card in this computer?
Since this is a laptop you won't be able to change the video card physically like the desktop computers. This Toshiba model has an ATI Radeon TM X1250 128MB-831MB dynamically allocated shared graphics memory. So that means by default it can provide a 128MB of graphics power, but if you increase the size of the memory you can also get up to 831MB of graphics memory therefore increasing or upgrading the available video memory of your laptop.
Dec 15, 2010 | Toshiba Satellite A305D-S6848 Notebook
Acer Aspire 5735-4774: Increase shared graphics RAM
It is possible but, only if you can change the video RAM allocation in the BIOS.
Apr 04, 2010 | Acer Aspire 5735 Notebook
Hey there, I have an Acer Aspire 7720. I checked in BIOS (v1.25) that only 8MB video memory is avaliable (out of 2GB), and couldn't change the settings. Could you help me solve the problem please?
dynamically allocated memory is borrowed from the system memory; ie, your GPU is using shared memory. Increasing the allocated VRAM is not going to increase your performance by much simply because this kind of video memory is so slow.
You might want to consider updating your graphics driver and checking your temps to make sure that the GPU isn't overheating.
Jul 01, 2009 | Acer Aspire 7720 Notebook
Acer aspire 4315 128MB to 358MB
Actually this 358 MB will be shared Ram not Dedicated and will be requested by application or game from Windows and then OS gives a portion of RAM temporarily for Grphics data this is how it works
and only u will be able to access 358 VGA mem when u have 2GB of Ram installed in ur laptop from 1 GB u can only get 128MB
Pls ask me for more guidance if u need
and rate me FIXYA fo rhelp
May 06, 2009 | Acer Aspire 4315 Notebook
I have a acer aspire 5100. I'm running vista sp1 ultimate 64x I have 4 gb of ram I'm having a very difficult time trying to plat Knights of the Old Republic (a game from 2000) I have a ati radeon xpress...
This model comes in 2 different flavors and I am unsure which one you have but here's the skinny on it:
Option 1:
ATI Radeon® Xpress 1100 chipset with integrated 3D
graphics, up to 256 MB of shared system memory
Option 2:
• ATI Mobility™ Radeon® X1300/X1600 with up to 512MB of
HyperMemory™ (64MB of dedicated GDDR2 VRAM;
up to 448MB of shared system memory), supporting
Regardless of which one you have, you should be able to set the shared memory in the BIOS, or you can use the Acer ePerformance Management software either installed on your machine already, or which can easily be downloaded from their website at this link:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Cheers!
-E
Jan 02, 2009 | Acer Aspire 5100 Notebook
Video memory
Where shared memory is present, the BIOS is used to change the memory size. On your machine you have a Mobility Radeon display card which has 128Mb of memory but the capacity to share a further 384Mb of system memory.
Most applications that show the memory, however, will only show 128Mb of memory since that's what the dedicated memory is. Although you can share more memory with it, it only has 128Mb of dedicated memory all to itself.
F2 when you turn the power on enters the BIOS and allows you to configure things such as video memory. There is strangely no data on it whatsoever in the Acer User Manual for this machine; "hypermemory" doesn't appear once in the entire document, so I'm not able to offer you any more direct support than to suggest looking in the BIOS.
Jun 01, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 5100 Notebook Logo
1,213 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
