Question about Saeco MC2002 Electric Burr Grinder
How to clean Saeco Coffee Grinder Mc2002
Help, I cannot pull it apart.
espressodoc
  • 29 Answers
SOURCE: saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Posted on Aug 27, 2007
JohnnyBeans
  • 223 Answers
SOURCE: Grinder will not stop
Try these grinder cleaning instructions.
http://www.cerinicoffee.com/custompages/Tech/Grinder_Adjustments_for_Italia.pdf
Great espresso Beans for superautomatics try:
http://cerinicoffee.com/Espresso_Coffee_Beans.asp
Posted on Dec 19, 2007
mirran
  • 515 Answers
SOURCE: Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Posted on Jul 18, 2008
EsWorld
  • 1618 Answers
SOURCE: How do you take apart the grinderon Saeco Spidem Villa Household Coffee Machine
Remove all the beans in the hopper, there are 2-3 screws in the hopper. Remove and then lift hopper, this will give access to the grinder chamber and burrs.
Posted on May 30, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Posted on Jun 03, 2009
The grinder grinds too long, then stops and then the bean refill light goes on, ---there are plenty of beans but no coffee being made. I think the grinder is not working somehow. Its a 5 year old Saeco...
The lever under the bean hopper is set to low. Push it all the way to the back.
There is a leverbehind the door in the middle top. Pull it to the minus and try again.
If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 05, 2011 | Saeco Royal Cappuccino Espresso Machine
Grinder runs but the machine indicates no coffee & no water signals!
Try pushing the lever on the right side below the grinder towards the back all the way and try again. If it clears the grinder is good otherwise it needs to be taken apart and cleaned.
Aug 11, 2010 | Saeco Magic De Luxe Espresso Machine
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Jun 03, 2009 | Saeco Spidem Villa
May 29, 2009 | Saeco Spidem Villa
Coffee watery
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 15, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Coffee beans will not grind
Your machine will probably need service. The water will cause damage to the grinder burrs.  I can send you instruction on how to clean out the grinder on a Vienna if you provide me will your email address. You can email me at support@cerinicoffee.com.
You are not the first person to do this. These problems come in at least once a week.
Hope this helps.
Johnny
Oct 08, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco MC2002 Electric Burr Grinder Logo
63 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
