When i turn it on it keeps flashing door?? - Washing Machines
  • 12,061 Answers
This usually happens if the Door isn't closed properly, OR the switch is faulty. get a service manual for your make and model.
Posted on Apr 27, 2010
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Feb 26, 2017 | Hotpoint Freezers
Mercedes a class 140 1999. Rear passenger door won't close or lock also turning ignition on hazard warning lights are flashing
Might be the harnes that is fixed to the boot lid hinge .Take a look at the cable running up inside it if its broken or damaged .Or the location of the wires, that go from the door to the body they are in a type of rubber concertina on most doors.
Aug 06, 2016 | Mercedes-Benz Cars & Trucks
Why won't washing machine start?
It is most probably the door sensor that is faulty. If the sensor does not sense the door closing the machine will stay in "open door" mode and will not start with it's program.
If the machine is still under warranty, take it in for repair or have someone check it out for you. It should be a quick fix, if parts are available.
May 24, 2014 | Washing Machines
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
My car keep flashing door and every time i make a turn or step on the gas the chime keep coming on
it is one of your door locks going on you you will have to figure out which door though.......unplug all of them ( inside of door ) and plug one in at a time until defect returns
Nov 10, 2009 | 1996 Chrysler Cirrus
Door light flashes, dome light flashes, locks keep trying to lock
My Neon did this.....The door sensors were messed up and i just ended up taping pennys to the little knob.....It was a idea from my co-worker who had a Neon and had the same problem....
Apr 20, 2009 | 2000 Plymouth Neon
Standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Oct 20, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Keyless entry keylob want lock or unlock doors or trunk.change battery and checked all fuses.
You need to program the remote. Get in to the car and LOCK all doors with the switch on drivers side door. Take the key and insert it into the ignition cylinder in and out 6-10 times, until the flashers/hazards flash on your dash board. Or just keep putting the key in and out (nice and easy now, not fast) until you see the lights on dash flash. After the lights flash, turn the key into ACC mode to make the whole dash light up.(do not start car) .With the key in ACC position, hit any button on remote, that will make the hazards flash again. Turn key off and unlock door with switch again. Open door.DONE.
Good luck.
Jul 15, 2008 | 2001 Nissan Altima
GREEN LIGHT FLASHES
when the green light comes on open then close the door its to remind you there are clean dishes in the washer and opening the door acknowledges this
Jun 01, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
"Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Mar 31, 2008 | GE Profile JTP56 Electric Double Oven
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
