Question about Fujitsu Heating & Cooling
Remote won't communicate with machine - Fujitsu Heating & Cooling
  • 34 Answers
Try the following until you achieve results:
1. Make sure power is turned on
2. Check batteries in remote are working
3. Lift front panel of A/C unit and press the test button beside the electrical cover on the right of the unit.
4. If unit still will not start then the computer control card is most likely damaged and needs to be replaced
Posted on Apr 27, 2010
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
May 14, 2012 | Televison & Video
GVA remote has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 10, 2012 | Televison & Video
My remote isnt working
Regards.
Jan 04, 2012 | RCA F27676BC TV
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
Washer won't start.....F70 code appeared It's a Whirlpool Duet
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My remote will not work the tv anymore
there are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
May 08, 2011 | LG 32LC7D Television
I have changed the batteries, but the remote still does not work.
Regards.
May 02, 2011 | Televison & Video
The remote doesn't work at all
First, if remote doesn't work, try new batteries......
Regards.
Apr 25, 2011 | LG 32LG30 32 in. LCD HDTV
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Heating & Cooling Logo
302 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
