Question about Brother MFC-685cw InkJet Printer
I have the Brother MFC-685CW Fax Printer, I replaced the Yellow ink cartridge but it still comes up with message "Yellow No Ink" What can I do?
  • 4,041 Answers
Hi there
You can try.
Just take them out and gave the brass connexions a good clean and put back.
All the best Pineworks
Posted on Apr 27, 2010
I have a Brother MFC 3340CN and 1940CN,fax,print,copier I was working fine and then all at one message was yellow out of ink please replace and start again. It has a brand knew yellow ink cartiage in it...
The ink that is given to you when you buy a new machine is not the same as if you went out and bought ink. The "starter" ink cartridges are not filled completely (that is a marketing gimmick to get you to buy more quickly). When you say "NEW" do you mean "new, never been used", or "new, just got it last week"?
If it's never been used, be sure that you have removed the protective tape from that cartridge. If it's been removed then the cartridge its self could have a problem or the machine could be at fault (not correctly reading the ink). You choices are to return it to where you got it, or buy a yellow cartridge and replace it.
If it was working and stopped after a very short time (a week or two) I would get a new yellow and try it.
For your sake I hope it's the protective tape was forgotten, it happens quite often.
Dec 23, 2010 | Brother MFC-3340CN All-In-One InkJet...
I have just replaced the black cartridge of my Brother 685CW printer and fax. Prompt says 'No cartridge". tried all the solutions above to no avail. I need to use printer urgently. Please help. Moh.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Sep 27, 2010 | Brother MFC-685cw InkJet Printer
Doesn't print black ink
Have you taken the protective film/sticker off the cartridge? - so the ink can get out...
May 06, 2010 | Brother MFC-685cw InkJet Printer
Where is the encoder strip on brother fax machines?
I am familiar wih some inkjet models. The encoder strip would usually be behind the ink cartridge carriage. It is a thin clear plastic strip across the length of the carriage. The ink cartridge housing glides back and forth along the encoder strip.
Aug 25, 2009 | Brother MFC-685cw InkJet Printer
Can't send fax because of message: Ink Empty Black-Replace Ink
No, the machine needs to have all cartridges installed to perform all actions, including fax and scanner functions.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Ink "new" , yet not registering as any in machine. Help please.
I'll bet you're using cheap generic ink, after having used real Brother ink cartridges. It sees and it knows the ink is generic (apparently by measuring the electrical resistance of the ink). I'm in the midst of the same issue and am going to try using real Brother cartridges to see if the problem goes away.
Sep 18, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Brother MFC-685cw InkJet Printer Logo
249 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
