Question about Air Tools & Compressors
Machine tripping out VSD 41 fault ,then restarts inself
  • alan_petchey Apr 29, 2010
    Ingersol rand Nirvana N75 kw compressor
    Drive unit MD 120 TIR
    Drive unit faults out VSD 41
    Machine goes to checking module then restarts itself
    ingersol Rand say power supply problem ??
    Machine been in 20 months no problem ,no other machine having problems and they have PLC or DNC control units
  • ddlafferty May 11, 2010
    the drive could be dirty or the drive filters could need to be cleaned ,need the type and model
Vsd fault 41
Posted on Jun 14, 2016
5 Suggested Answers
  • 205 Answers
SOURCE: IR Compressor sl.No N37
Yes, the control board may be bad . Ihave attached a procedure for checking the hall effect sensors, some of which you will not have the special tool needed to preform all the tests. However it will allow you to check the control board which may be bad causing your problem.
VSD FAULT DIAGNOSTIC GUIDE
10 Revision 001 - March, 2002
Appendix 4 - Hall Effect Sensor Checks (Four Part)
1. Isolate the compressor from the main incoming voltage supply. Lock and tag the
isolation switch in the open position.
2. Allow 15 minutes for the VSD to discharge capacitors.
3. Open enclosure doors to expose the VSD.
4. Check with a suitable meter that all voltages have dissipated before beginning work on
the VSD.
5. Remove rear cover of drive motor to permit rotating by hand.
TEST 1
6. Disconnect Hall Effect Cable from P4 on the Control Board, plug type is DB9 Type.
7. Inspect cable pins and matching receptacle connections for damage or bent pins.
Remove cover of plug and inspect solder connection of the wires for damage.
9. Inspect entire length of the cable for damage. If cable and connections are in good condition,
proceed to Test 2.
TEST 2
9. Confirm supply voltage to the Hall Effect Sensor is present using a digital multi-meter.
10. Disconnect terminal strips P1, P2 & P3 from the bottom of Control Board.
11. Trip and switch off MCB2 and MCB5 to prevent the SGN Intellisys from powering up.
12. Re-connect main incoming supply voltage to the unit. Isolation contactor KM1 should remain
de-energized and the VSD should only receive control power. Caution must be taken as the
panel has voltage present.
13. Set digital multi-meter to DC Volts.
14. Connect Black probe of multi-meter to either of the 2 pins of P16.
Note: P16 is located on the Control Board, slightly less than half way down and towards the left side.
P16 is marked and described as 2 small bare pins. P16 is the ground connection for the Control
Board.
15. Locate the small transistor just above Pin 3 on terminal strip P1. The transistor has 3 pins on
the left side. The pins are numbered 1 at the top, 2 in the middle and 3 at the bottom.
16. Connect Red probe of multi-meter to Pin 3. The voltage should be between +11 and +14 Volts
DC.
17. If voltage is not present, replace the Control Board.
11 Revision 001 - March, 2002
TEST 3
17. Connect special adapter XXXXXXXX between P4 on the Control Board and the Hall
Effect Sensor Cable.
19. Set digital multi-meter to DC Volts.
20. Connect Black probe of multi-meter to either of the 2 pins on P16.
21. Connect Red probe of multi-meter to Red wire of the adapter. Rotate motor by hand and
observe measurement. The meter should read between +10 and +12 Volts DC.
22. Repeat the test with the Black wire of the adapter. The meter should read between +10 and +12
Volts DC.
23. Repeat the test with the Yellow wire of the adapter. The meter should read between +10 and +12
Volts DC.
24. If voltage does not rise to between +10 and +12 Volts DC for any of the 3 sensors, replace the
Hall Effect Sensor Assembly.
TEST 4
25. Set digital multi-meter to Ohms.
25. Connect multi-meter between Purple and Green wires of special adapter XXXXXXXX. The meter
should show a resistance value of approximately 150 Ohms ± 20% (New Hall Effect Sensors)* at
70° F (20° C) ambient temperature.
27. If correct value is not confirmed, replace the Hall Effect Sensor Assembly.
Note: Two temperature ranges (130° C and 150° C) of Hall Effect Sensor have been used. Typically,
the 50/60hp (37/45kW) units use a 130° C sensor and the 75/100hp (55/75kW) units use a 150°C
sensor. All sensors have a small band near the sensor end of the cable.
The 130° C sensor has four digits such as 6622 on the band. The 150° C sensor could have either a
four digit number with a star on each side (*6752*) or a four digit number followed by a star and the
letter E (6752*E) or a four digit number followed by an E (7652E).
Appendix 5 - Megger Main Motor Windings
Posted on Sep 18, 2011
  • 21 Answers
SOURCE: Navana Fault POWER MODULE TIME OUT. Cannot start machine
Sounds like a communication fault between the control and the drive.
Check visually if the 15Vdc power supply is present on Control board.(Led D45, located on left up side)v
Posted on Oct 04, 2014
  • 41454 Answers
SOURCE: IR Ingersoll Rand 75 kw air pressure compressor. Set pressure reached cut off. But restart time VSD fault 41 come. What is this problem solution.please help
Contact Ingersoll/Rand through their website .
Posted on Oct 10, 2015
hassan_abada
HELLO I nedd ingersoll nirvana vsd fault diagnostics manual.
thanks
Posted on Oct 23, 2015
IRN50H-OF Getting random VSD Fault 22 and VSD Fault 36 does anyone have a published list of fault codes, or know what these mean?
Not that I am aware of and we have no way of looking any up as we do not know the MAKe /model try Google
Apr 04, 2016 | Air Tools & Compressors
Plase help!VSD fault 2 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw
Vsd fault 2 is a current imbalance. Check your current readings and compare them to those on the intellysis display they should match, also check for a imbalance in amps. After that it gets more complicated using board diagnostics etc
Sep 12, 2014 | Air Tools & Compressors
Please!!!VSD fault 7 and VSD fault 1 Problem with Ingersoll Rand Air Compressors nirvana n37 37kw. thanks!
Vsd fault 7 is a fault with the hall effect sensors inside the motor, more than likely they will need replacing.
Sep 10, 2014 | Air Tools & Compressors
yes. when one of the phase is out, the other two power module is usually overloaded and burnt. swap it.
May 19, 2014 | Ingersoll Air Tools & Compressors
VSD fault 7 Problem with Ingersoll Rand Air & Gas Compressors nirvana n37 37kw
plz any one help us vsd 7 fault and the compressor does not start and the fault appears
Mar 21, 2014 | Ingersoll Rand Air Tools & Compressors
IR Compressor sl.No N37 - 75KW NIRVANA -TEO179V05257 (oil free screw compressor). Machine trips with VSD 8 fault. Hall effect sensor is new one and is connected as per the correct sequence. Are there...
the VSD.
TEST 1
proceed to Test 2.
TEST 2
Board.
DC.
TEST 3
Volts DC.
Volts DC.
TEST 4
Sep 17, 2011 | Ingersoll Rand Air Tools & Compressors
Air Tools & Compressors Logo
1,782 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
