I would like to flatline my laptop back to factory settings
    Novelist:
  • 151 Answers
Hello sxc_lil_maz
You can do this is by doing a clean install with the installion CD you received with your laptop. If you're not in posession of it, you can contact your laptop manufacturer, who can usually send you a replacement. Insert the CD, and follow the on-screen instructions.
Remember to back-up any documents you may want to keep. The easiest way to do this is go to "My Computer" > "Local Disk (usually C:), and then copy the folder "Documents and Settings" to an external media (CD/DVD/external device).
I hope this answers your question and is of help to you. If you require any more assistance, please do not hesitate to ask.
ajblaj
Posted on Apr 27, 2010
How to take laptop back to factory settings
Depending on the brand and year it was made there may be a factory partition that will restore computer back to factory defaults, if not then a reinstallation of windows will be necessary, If factory partition is available just do a search o Google with your make and model # such as : How to restore an Acer Aspire 7425 to factory defaults using recovery partition
Mar 15, 2014 | IBM ThinkPad T40 2373 Notebook
Toshiba 32a40. The display on the screen shrinks to where it looks like a BLUE FLATLINE. I bang on the sides and the upper back portion of the TV and the image comes back temporarily. But now nothing...
You've got at least one board that's gone bad. Were it mine, I'd donate it to a local charity and get a new one. The charities have volunteers and job trainees that do the repairs, and might be able to make a buck on it, while you get a tax write-off.
Jul 07, 2011 | Toshiba 32A40 32" TV
My a5 has no pressure with my flatline installed, and works fine with stock barrel... pleASe explain
Have you chrono'd the gun? This test velocity. This makes no sense unless your
gun is actually shooting VERY slow. In that case the way the flatline works, the ball rolls thru the barrel,
would really slow down a ball passing thru. That is my bet, low velocity. I use the same gun.
Adjust your allen screw in to make more pressure and try the flatline. Man I love the flatline with
an e-grip. Scares the **** outta the long distance players!
Here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 18, 2011 | Tippmann A 5 Standard Paintball Gun
How to install a 98 flatline barrel to a project
In order for you to install the 98 flatline you need an adapter, if you don't have the adapter I would try to bring it back to the store so they can install it for you.
Jun 09, 2010 | Tippmann US Army Project Salvo Sniper...
HOW DO I SET MY LAPTOP BACK TO FACTORY
For (Operating Systems=windows98,xp,vista)
unless you have a custom program to do this you can only restore back using (system restore) however that will not restore it to factory settings.. the best way is simply re-installing the Operating system after Formatting your entire Harddisk space (all partitions)
If you don't know how to do it.. then simple follow the instructions after booting the windows CD
PS: to boot windowsxp cd you have to set BIOS settings (F2 or F10 or Del Button at start of computer) to boot CD before HDD..
There is no simple restore factory settings in Laptops
Jul 16, 2009 | Computers & Internet
Fault code po420 ; is problem sensors or is it the cat conv
The only thing that will set this code is the catalytic converter or the oxygen sensor behind it. Way to tell if it is the sensor is to monitor voltage reading with scan tool and see if it is fluctuating the same as the upstream oxygen sensor. If it is the converter is "free flowing" and will have to be replaced. If the sensor is "flatlined" then it is most likely bad and setting the code.
Apr 30, 2009 | Ford Fusion Cars & Trucks
Factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Mar 15, 2009 | Acer 4220-2346 Notebook
Restore to factory setting
If you want to completely reset it back to the original windows settings you must re-format your computer. This won't put the original programs back on it that you had before, but it will give your computer a COMPLETE reset. Meaning also that if you want to keep some data you must put it on some external drive because your hard drive will be completely overwritten.
If you want to get it back to just the factory settings, you could try to contact their customer services if they don't anything on their site to help you, although I would not recommend it. Factory settings aren't the best because they usually put stuff on your computer that you don't really want. Re-formatting is the best thing to do.
Nov 09, 2008 | Toshiba Satellite L25-S119 Notebook
Flatline
Please ensure that all the wires connecting to tv are not loose. Keep the air vents of Tv clean and airy. Let it cool if u watch it whole day
Mar 09, 2008 | Televison & Video
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
