My home movies, burned to DVD-R disks, work perfectly on my old Bush (conventional type screen) TV. A new (wide screen type) Bush TV just won't allow them to play and a message 'unknown disk' appears (a commercial DVD does seem to play OK). Obviously the DVD player is OK because I use it regularly for my home movies and I used it for both trials. Is it some sort of code in the television set which must be 're-set' so it can play my movies?
-   I have a Go Video Dvd recorder and vcr unit.The dvd recorder seems to hangs up and and after initial initialization will produce message unknown disc error or unknown disc.then it says check disc again message.Please advise.
Robert-   10Gambler
Jun 19, 2008
-   I had several hundred slides put on a dvd. I can play it on my my Pioneer DVD Recorder and VCR. I made several copies on the Pioneer unit (play the vcr version and it copies to a dvd. I can play them on the Pioneer unit after burning, however we can't play it on a prtable DVD and my daughter can't play it on her unit. I used DVD-RW discs initially, but I saw that the original was on a DVD-R. I made a copy on the new disk, and still have the problem.
Some units jusy won't play certain types of recorded DVD discs. I would transfer one to a DVD+R type and see what happens. Buy a good brand like Memorex.
Mi grabadora no graba DVD pero los lee correctamente. No puedo instalar los controladores:...
(More)
Mi grabadora no graba DVD pero los lee correctamente. No puedo instalar los controladores: "Target drive is not found correctly"
I have an external pacific digital cd-rw burner. I have windows vista and I would like to use this...
(More)
I have an external pacific digital cd-rw burner. I have windows vista and I would like to use this burner to make cds directly to the computer cd burner. How can I get the update for this and be able to use it
dvd/cd driver won't work.Message says thisvdevice has been disabled, Analternative driver may be...
(More)
dvd/cd driver won't work.Message says thisvdevice has been disabled, Analternative driver may be providing the function
