Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Rattle, wont freeze
Rattles, wont freeze
  • Amana Master
  • 43,501 Answers
The compressor is not starting...these tips will help you with that...
Try change the start components....potential relay and start capacitor...if that don't work it is the compressor going bad...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Thanks! You helped me to understand the relay and capacitor's purpose,and why a change in either may cause the compressor not to start. "
Posted on Apr 27, 2010
16 years old. cold inside, but not freezing food. making small rattling noise
check the RepairClinic site, as they indicate what may be wrong when there is a 'rattling' noise in a freezer
Jan 13, 2016 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Rattling noise that stops when you push in clutch also cluch peddle has been hard to push in since clutch replaced a year ago
Whenever you hear a tap, rattle or thumping noise take to a mechanic or someone who knows cars you do not want to blow a rod through the block. It could be starting to freeze take it in!
If you need further help, reach me via phone at https://www.6ya.com/expert/cynthia_0eebb7da17b33b5e
Mar 18, 2015 | Cars & Trucks
My 01 Blazer is completely will not start. There is no turn over sound; Absolutely no sounds at all.
You could have serious trouble with the engine losing that much anti-freeze. If it is not leaking out somewhere onto the ground, it may be from a bad head gasket that is letting coolant burn in the cylinders (you would see white smoke out the exhaust), or it may let the coolant get mixed into the oil in the lower engine's crankcase.
Pull the oil dipstick and look at it. If the level is way high, or if the oil color is milky brown looking, then you have water (anti-freeze) in the oil-a bad head gasket, and a big expense to fix it. That would explain the rattling: water in the oil stops the oil from lubricating properly, and the engine bearings and other moving parts inside the engine can be damaged. If this is the case, and the reason for the rattling, then the engine is shot and needs a total overhaul, or you need a different engine.
If the coolant was leaking outside, post back. Has the engine ever overheated from low coolant? The rattling is worrisome-have a mechanic listen to it if you get it started. If it won't crank over, have someone see if the engine can be turned by hand-if it still turns freely (not siezed up), then the starting circuit needs to be checked for why the starter won't work. Good luck. Check the oil first thing.
Feb 08, 2013 | 2001 Chevrolet Blazer
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
When i try to acclerate the car wont speed up...when i stop to long and try to go again the car stalls and then grinds...there is a continuous rattling noice also
I would first have the fuel pressure checked you may have a clogged fuel filter or a weak fuel pump. as far as the rattling that could be anything hopefully its not the engine rattling make sure you have oil in the engine and maybe the rattling is a loose heat sheild, good day.
Sep 03, 2011 | 1999 Buick Century
Think my cambelt has broken on my toyota picnic and has been since started and making a heavy rattling noise!! does this mean i require a replacement engine? or can i get away with getting it repaired?
Repair it ....A rattle could be anything simple....Normally it is a splashguard or a heat shield that can rattle and make you think it is bad and it wont be.....Have it inspected first ....
some rattles can be a bearing noise from a waterpump or an idler pulley ....etc.....
All vehicles are repairable normally......It could be very simple....I see it all the time...have faith
...The timing belt is common.....Also waterpump.............Hope this helps............Metalpoet
Apr 17, 2011 | Toyota Previa Cars & Trucks
ABB2224DEB Freezer is not freezing. Compresssor comes on frequently with a loud rattling sound. I cleaned the coils. I had a lot of dust and debris under the unit.
sounds like a compressor . and only repair would to replace the comp.. rattling noise is internal and ther is no repair for comp ( just replace ) mm
Jan 20, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
1995 wrangler ..... gas gauge and temp gauge wont work...also engine seems to run fine but when you turn it off it rattles sounds like change rattling a little...no idea????
There might be a bad fuse for the gauges. I believe the fusebox is in or behind the glovebox. The rattling maybe a heatsheild underneath, or maybe a loose clamp?
Oct 24, 2010 | 1995 Jeep Wrangler
Rattling nosie from engine
I would say that you have run it out of anti freeze and done internal damage to the motor by the sound of it.
May 11, 2009 | 2004 Chevrolet Silverado
Rattle in under dash
IT COULD BE A EXHAUST HEAT SHIELD ALOT OF TIMES IF THAT IS WHAT IT IS I JUST REMOVE THEM IT WONT HURT ANYTHING CHECK ON TOP AND BOTTOM OF YOUR CATALYTIC CONVERTER
Apr 20, 2009 | 1999 Honda Civic
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
119 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
