Question about Philips Televison & Video
Lost my code paper for my philips universal remote
    Sniper:
  • 52 Answers
Unfortunately as you haven't mentioned the particular model number of your remote control so I can't give you to the exact information that you may need. However I can give you the link to the Philips remote control support web page where if you type in the model number of your remote and click "Find It" it will hopefully take you to the dedicated suppoert page for your remote. On this page it will contain the manual and also help for the code list if it isn't contained within the manual.
Hope this helps,
James
http://www.support.philips.com/support/catalog/products.jsp;jsessionid=0E18DDF8FDFF880FB531861BE6F0E590.app107-drp1?_dyncharset=UTF-8&country=&categoryid=REMOTE_CONTROLS_SU1_GB_CARE&userLanguage=en&navCount=22&groupId=SOUND_AND_VISION_GR_GB_CARE&catalogType=&navAction=push&userCountry=gb&title=Remote+Controls&cateId=REMOTE_CONTROLS_CA1_GB_CARE
Posted on Apr 27, 2010
SOURCE: i need codes for philips universal remote control
call 1-919-573-7854. Know the TV model and they will give you the codes
Posted on Apr 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
aprmaejun
  • 97 Answers
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
aprmaejun
  • 97 Answers
SOURCE: i lost my remote codes
Hope this helps :)
Posted on Jun 23, 2008
SOURCE: i lost my manuals to my philips universal remote how do i program it wthoout using the code
buy another one
Posted on Oct 02, 2008
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Codes for remote
hi can you tell me your model number of your remote controle
Dec 09, 2008 | Philips Magnavox Learning Universal Remote
Lost paper to my PHILIPS universal remote NEED CODES
I have the manual for a Philips universal remote that lists 441 and 442 as code for Magnavox DVD players.
Nov 19, 2008 | Televison & Video
Rrmote control codes
i need the code for philips universal remote i lose the code
Oct 01, 2008 | Directed 434MHZ Remote Control
I have a philips universal control remote P335
visit www.urc.philips.com
use the drop down menu on the left to find your remote.
it should bring up a choice of viewing the manual or using the code finder. You will need the manual first to make sure you know how to program the remote, then use the code finder to get the codes for your specific device.
Aug 01, 2008 | Philips Magnavox Learning Universal Remote
I lost my remote codes for my philips US2-PM435S
Lost my remote codes for my philips remote. I need the combo codes for a tv, vcr,and dvd.
Apr 20, 2008 | Philips Magnavox Learning Universal Remote
Looking for Code
i have a philips universal remote and lost paper with codes for my tv... please help me it is rca-truflat tv
Dec 31, 2007 | Philips PM3S Remote Control
Televison & Video Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
