Question about Toshiba RD-XS34 DVD Player/HDD Recorder
DVDR 3350H KEEP READING AND WON'T EJECT DISC
Hi, my DVDR3350/H is "reading" an DVD-RW disc, gets frozen and stop to respond. I cant power off by remote or stand by button, just unplug from the power outlet. And reconnect, again then eject button dont work and keep reading ......
What can i do ? Thanks
You will have to open up the unit , remove the dvd unit and in front of it is an square hole about 5mm across , then straighten a paper clip an push it into that hole
the tray will slide out then
Posted on Jul 29, 2010
I'm having the same problem with my TOSHIBA RD-XS34SB and have tried everything. There is no "small hole" that I can see, and so am totally stumped.
Can anyone help?
Thanks in anticipation,
Chris
Posted on Nov 03, 2008
    Master:
  • 518 Answers
Look under the faceplate where the disc tray ejects and see if there is a small hole. If so, use a straightened paper clip to eject the disc manually by pushing it into the hole about an inch. If that works, then reset the power on the unit and try a nonrecorded type disc to see if the unit works at all.
Other than that, you'll have to take the unit apart to get your disc out.
Hope that helps...
Geno
Posted on Mar 24, 2008
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
How to play a .flv file
you need to convert FLV to DVD with a DVD Burner.
then it can played in your DVD player.
maybe you can take a try for this one i recommend to you which i think is perfect.
Jul 10, 2012 | Magnavox Zv427mg9 Dvd/vcr Combo - Dvdr/rw-...
What do + and _ signs mean on blank dvds
- RecordNow! can record only to the same disc type
it records from. For example, you can record a
DVD only to a DVD+R or DVD+RW disc, and you
can record a CD only to a CD-R or a CD-RW disc.
you were using DVD-R, so it won't work.
hope this helps
Jun 18, 2012 | Verbatim Blank DVDR Discs/DVD R Media -...
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
DVD ROM CANT READ DISC
Please go and buy a new dvd writer in place of dvd-rom.
Dec 05, 2007 | Memorex (32023244) CD-RW/DVD-ROM Combo...
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
LaCie DVD RW won't open
use a paperclip and manually eject the disc....recycle the unit, power it off then wait then power it back on and it should be seen be available again i hope this works for you ps put paperclip into tiny hole in front of disc drive....thx
Jul 06, 2007 | LaCie (300978) DVD RW Dual Layer Burner
Dvd not reading disc it just wrote
you might try + media also see if there is an option to finalize the disk.
Apr 19, 2007 | Toshiba (SD-R6112) DVD-RW Burner
Toshiba RD-XS34 DVD Player/HDD Recorder Logo
261 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
