Question about Targus Wireless Optical Notebook Mouse PAWM10U
Targus pawm10 mouse doesn't work
Need identification code for pawm10 wireless mouse. That's what it say's in the manual to get it to work. How do I do this step?
  • 1 more comment
  • Anonymous Aug 28, 2008
    lll
  • leclairfam Jan 10, 2009
    It worked "once upon a time" (about 2 years ago), but won't activate the cursor now boohiss. Hopefully someone can help! =])
  • seragan82 May 11, 2009
    My mouse work in the past but one day I took out the usb drive and when I returned it no longer worked. Is there any way to correct this problem?
If you have a problems whit this muse onli pick the balck reset button from down RF USB and mause have 1 too pick too and the ligths flashing 3 sec and ready to used it cyaa srry 4 my eng
Posted on Oct 02, 2009
    New Friend:
One thing you can try if you can't get this mouse to work is to hit the little black button on the USB that the mouse came with. When the USB is plugged in, there is a blue light on the end, the little black button is right next to the light. Hold it in for a second and the blue light should flash for a couple seconds. The mouse worked for me after doing this.
Posted on Dec 24, 2009
SOURCE:
It has a very weak red lightmy mouse stopped working
It sounds, to me, like the batteries need replacing. There is a diagram in the user manual here:
http://www.targus.com/us/Downloads/PAKP003_UG.pdf
Oct 29, 2010 | Targus Wireless Optical Notebook Mouse...
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
I have a Targus wireless usb mouse model AMW 1602EU. My new laptop (windows vista op sys) does not see the mouse. Do I need to download a driver for this mouse. In addition their is a small black button on...
I corrected your spelling of 'Targus' to help others in the future.
After you have pressed the button on the USB receiver you have to press the button on the under side of the mouse. Then it will work.
Your manual is here. See the bottom left panel and the illustration.
http://cdn.targus.com/web/uk/downloads/amw1602eu_user_guide.pdf
Jan 09, 2018 | Targus Computers & Internet
Targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Aug 24, 2008 | Targus Wireless Optical Notebook Mouse...
My targus wireless mouse
I had this happen to me after reprogramming my tv remote too close to my laptop and mouse. Try resetting the reciever and then the mouse by pushing the reset buttons on each one while they are plugged in ( reciever first, then the mouse ).
Apr 05, 2008 | Targus Wireless Optical Notebook Mouse...
HOW TO SET UP AND USE TARGUS WIRELESS COMPUTER MOUSE
I assume this is a wireless mouse, Is there a similar button on the reciever? press this at the same time as pressing the one on your mouse
Mar 06, 2008 | Targus AMU18US Mouse
My targus mouse model pawm001
Yeah, I was kind of confused about this too. Apparently, on the base of the mouse, there is a red reset button. Press it, while simultaneously pressing the black reset button on the base of the USB-connected charger. The laser light should become steady after a moment, indicating that the mouse is in sync with the laptop. If the laser is blinking, however, then the mouse is attempting to become synced. You may have to press the reset button multiple times. Hope this helps.
Dec 21, 2007 | Targus PAWM001U Mouse
Targus Wireless Optical Notebook Mouse PAWM10U Logo
3,169 people viewed this question
Top Targus Computers & Internet Experts
Raj Patel
tony wahlman
tony wahlman
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
