Question about Plumbing
How do I change washers in a verona toilet suite. I have changes the smaller ones but cannot find where the large washer goes. Thank you
Hi I have Verona 6-3 toiltet and its leaking can you please tell me what size washers do i need to replace??
Posted on Mar 31, 2011
Dont know how to put my clutch back on my polan 3416
I believe this model has an inboard clutch, so there should be a large backing washer that goes on first, this is followed by the clutch, this just spins onto the crank anti clock wise and tighten up against the backing washer, once on there is a smaller washer then the clutch drum, this is then retained with a dished washer and a circlip
Nov 17, 2012 | Garden
Toto Pacifica Gmax elongated toilet problem. Same problem I cannot solve. I can replace the flapper, no sweat. But I have replaced the large ring gasket, located on the plastic exit port of the tank,...
Hi, Dayne here
Those large gasket seldom leak unless the two bolts are not tight enough. DO NOT over tighten. The water is probably coming from the bolts themselves. The rubber washer goes on the inside of the tank, and then a nut should be on the outside with a metal washer. Tighten pretty tight, but not too tight.
Thanks.
Dec 12, 2010 | Home
Toilet bowl water keeps running eventhough flushing already finished or eventhough water in the tank already full. Model CST414M (elongated TOTO toilet). I appreciate your immediate assistance.
Look at float level, be sure that you are not running water into the overflow tube. Is the inlet valve closing? Pull the little tube that goes from the inlet valve assembly to the overflow tube and observe... Check the flapper valve for distortion, deterioration, or buildup. If anything is there, replace it.
Sep 26, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank?...
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Aug 31, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Theres a leak between tank and commode what needs replacing?
There are three rubber washers. There are two small ones under the heads of the bolts that pull the tank and the bowl together. (If this is a new toilet, it could be that these need a little tightening, but don't break it!) There is a large rubber washer where the water goes from the tank to the bowl.
f this is an old toilet, turn off the water, remove the water, remove the water supply pipe from the bottom of the tank, then remove the two bolts holding the tank and bowl together. Lift off the tank and you will see the rubber washers. Remove them and clean. Hardware stores have replacements. It might help to take the old washers with you to the store. You should replace the bolts if they are corroded. They sell kits that have the bolts and all three rubber washers included. Good luck. Al K
Aug 30, 2010 | Sterling Home
I have a 2002 pontiac sunfire. replacing starter. starter has 3 cables going to it. obviously the small cable goes to the small terminal. can you help me with the other 2.
the large cable goes on the terminal with the large nut and lock washer....the other goes to the terminal marked with an R or S depending on where the smaller cable hooks to...neither of the two smaller ones should fit to where the batt cable wire does...good luck, hope this helps....pappy
Mar 26, 2010 | 2002 Pontiac Sunfire
Just bought a cedo rue soft close. any idea of order of washers going on etc as instructions unreadable
Metal peg fixing goes "into" large plastic "cup" washer. Metal fixing now goes through holes in toilet pan sitting in the "cup" washer. From the bottom push up the thin round plastic washer, convex side towards the hole. Next the oval shaped thick washer flat side towards the hole. This has a cup shape into which the final plastic screw fitting pushes into (like a coax plug on the TV aerial). This will push up the thread into the cup where the sides force the thread to grip. Finger tighten so that you can still move the metal fixings from the top. Line up the toilet seat holes and push fit onto the pegs. It may take a smart thump to get them fully seated. Before tightening with the supplied black plastic spanner" make sure the large "cup" washer on top has not got trapped under the metal fixing. If all is ok line up the seat and tighten.
Dec 24, 2009 | Home
Where do the two little washers go in the oil filter casing?
hi, seal ring for drain plug and seal ring for bolt in oil filter housing,sometimes the manufactured give additional seal ring for different use,ty
Mar 29, 2009 | 1987 Mercedes-Benz 300-Class
Plumbing Logo
463 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
