Question about Samsung Washing Machines
I have a Samsung WA13G7Q1 washing machice The
I have a Samsung WA13G7Q1 washing machice The problem is that the cold water inlet does work (does not fill water through the cold water inlet). When I change it to the hot water inlet this works. What could cause for the cold water inlet not to work?
  • Anonymous Mar 17, 2014
    will not fill with hot water only cold water
The quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Posted on Apr 27, 2010
I have a samsung toploader wa13g7q1... it uses approximately 420 litres of water per wash.. full load... is this normal?
Do something good for all your skin. Use natural natual skin care products. These do not contain harmful chemicals, unlike synthetic ones that damage your skin over
http://www.toptryloburn.com/vita-luminance/
Mar 29, 2016 | Samsung Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
I have a Samsung Top Loader fully automatic washing Machine WA13G7Q1 and only a little water runs in then it stops. What could be the problem?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 12, 2011 | Samsung Washing Machines
I have a samsung sw52asp top loader ..it fills but wont switch off water and go into wash cycle it just overflows...help
  1. It sounds like your Water Inlet Control Valve may be getting stuck, or is stuck. There are 2 water inlet control valves, 1 for hot water and 1 for cold water. Does this problem happen when using the hot water only, or cold water only? You will need to replace the water inlet control valve for the side that is stuck open.
  2. If this problem happens with hot water and cold water, you may have a faulty control board, which will need to be replaced.
Mar 01, 2011 | Washing Machines
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
Samsung wa13g7q1 gives se error
Please check the following :
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Jan 20, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
627 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
