Question about Dell W2607C Television
I have a Dell television model W2607C that does not power up. The power light is not coming on.
  • Dell Master
  • 3,866 Answers
Common
The dell powerboard inside is bad and is verry common in these dell tv sets and the cost to get another one will be expensive around $150-$200 if you can find them.
join the community of people that do help:
http://en.community.dell.com/dell-groups/digital-entertainment/f/3506/t/19015505.aspx
but very good luck to you with your dell tv and the part as there going to be HARD to find as allot of people are having the same verry issue. Please do not hate the messenger our service does help but in rare complex issues like this we only can give information and pray for your good faithful ratings and feedback, thanks
Posted on Apr 27, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Apr 30, 2010
    I do not know how this was somewhat helpful, hmm
  • Mike Sullivan
    Mike Sullivan Aug 17, 2014
    In almost every case of a power up failure it is a missing voltage or low voltage, so checking this is where to start, then as a back up, look at the power board capacitors which are the reason for low or no voltages. Replacing a capacitor is easy, so look for bulge on top of all the capacitors and usually it will be obvious. Why spend big money for a pc board when a $5.00 capacitor will fix problem.
  • Dell Master
  • 12,061 Answers
Support.dell.com/support/edocs/systems/w2607c/.../dao_om.pdf
http://www.lcd-repair-review.com/dell-lcd-monitor-disassembly-and-mainboard-replacement
support.dell.com/support/edocs/systems/w2607c/.../dao_om.pdf
You most likely have a power supply fault, I looked for a service manual for your make model, but couldn't find any.
Testimonial: "Thanks that is what I thought"
I have a dell 42'' plasma w4201c and it will also not power up
Posted on May 30, 2010
2 Suggested Answers
  • 5 Answers
SOURCE: Model W2607C. Does not power up.
Check all of the fuses inside. If none are blown, unplug and hold power button for 20 seconds thus resetting all of the capacitors. Plug in and hold power button for 20 seconds thus powering the capacitors up safely. should work
Posted on Sep 04, 2009
Why won't it stay on?
can you please provide a fuller description of the issue and repost ...thanks....this is too little to go on
Aug 07, 2015 | Dell W2607C Television
Dell W2607C LCD TV won't turn on
Check and replace its main power regulator board. It might be faulty. Normally there is no repair to these boards. Card base replacement should be done.
Feb 07, 2013 | Dell W2607C Television
Where are w2607c fuses
Fuses can be located at its mains power supply regulator board inside.
Jun 11, 2012 | Dell W2607C Television
Where is the oscillator you refer to on w2607c blinking amber light?
Sep 25, 2011 | Dell W2607C Television
Dell TV has flashing amber light in lower right corner. TV will not power up.
Bad capacitors in Power supply, they maybe bulging out on top
Apr 29, 2011 | Dell W2607C Television
I have a w2607c that doesn't display when I turn it on. I got the Dell screen to appear once. but after that there will be nothing, the power light will just blink Blue. It doesn't turn amber at all. ...
You need to troubleshooting it to narrow down to which board is bad, it can be the power supply board or the backlight inverter baords.
http://www.shopjimmy.com/catalogsearch/result/?q=Dell+W2607C
You need to do the voltage checking and visual inspection.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 13, 2010 | Dell W2607C Television
Check the 27 mhz oscillator on the back of the main board. Resolder of replace it. It causes lots of different blinking amber lights.
Sep 04, 2009 | Dell W2607C Television
Fail to back on
Yes,Ur power ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Dell W2600 26 in. LCD Television
I recently received a Dell W2607C LCD TV from a friend...when I turn the unit on, I get a blue light that appears to be a stand by light. However, there is no picture at all. Please advise.
first check with a different cable , if it still doesnt come on , then you have to open it up and look for a burnt or cold solder where the transformer is ,also look around for any other solder. hope this helps AJ
Dec 17, 2008 | Dell W2607C Television
Dell w2607c
Had same problem too with my w2006c. Died after 6 month, replaced, then died after 8 month !!  Patrick Québec Canada
May 08, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
Televison & Video Logo
1,535 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
