Question about AOpen F90JS (Black) 19 in. Flat Panel LCD Monitor
Moniter won't come on
I shut down my computer for the weekend and when i started it up the moniter would not show anything. the button on top just flashes...can you help?
Onde consigo um esquema da placa do monitor aopen f95js
Posted on Aug 24, 2008
    Genius:
  • 1,913 Answers
Hi
check your ram.put ram away and check your bip is comes on or not .if u get long bip your cpu is ok.and your ram pro.
clean your ram and fix it again.
clean oyur processor case.
clear your bios .
pls take step one by one.
Posted on Mar 24, 2008
6ya staff
SOURCE:
Last weakend i drove about 400 miles ,the truck ran smooth all weekend untill we got off the freeway it started idling very rough ,i thought it was going to shut off so i cept the idle speed up when...
YEA, REPLACE EGR VALVE, ALSO, REPLACE AIR & FUEL FILTER, OXYGEN SENSOR SHOULD ALSO BE REPLACED !!!!! DON'T KNOW WHAT YOUR CODES ARE @ THIS TIME, BUT TAKE TO A AUTOPARTS STORE, THEY CAN PULL THEM & LET YOU KNOW ! MISFIRE MAY BE YOUR KNOCK SENSOR, ACTING LIKE A MISFIRE . EGR VALVE IS KNOWN TO GET CLOGGED UP, SEVERELY ! MAP SENSOR MAY BE ACTING UP ALSO, ALL SENSORS WORK TOGETHER, IF ONE STARTS GOING BAD THE OTHERS TRY TO ALONG WITH THE COMPUTER TRY TO COMPENSATE, YOU ONLY NOTICED IT AFTER FREEWAY, BECAUSE @ HIGHER THROTTLE, IT WILL NOT SHOW UP, THE TRUTH CAME OUT WHEN YOU GOT OFF THE FREEWAY ! VERY CONDISENDING , ESPECIALLY WHEN YOU THOUGHT YOU WHERE HELPING TO BLOW OUT THE ENGINE TO RUN BETTER,. YOU SHOOK SOMETHING LOOSE. BETTER AFTER FREEWAY, THEN ON IT.
Mar 24, 2013 | 2005 GMC Sierra 2500HD 4WD
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
The problem is in the power supply board often caused by one or two capacitors that open, some will show a bulge at the top making it easy to spot.
Mar 23, 2012 | Acer AL1916W 19" WideScreen LCD Monitor
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Shut down laptop, wont come back on, no lights or anything.
Not a good thing to do, I had a client that left for a weekend, had his laptop on the arm of his sofa and came back to find the laptop fried. If you left it on stand by and it was left on a surface that obstructed airflow, it probably overheated and severely damaged your computer.
My client's la[top overheated so badly that it melted the label off the bottom of the computer. He was lucky it didn't cause a fire.
Check for signs of burn marks and smell for burnt components.
Sep 20, 2009 | Computers & Internet
Moniter doesnt show anything
ok check you video driver because if your moniter is working with other computers then that could be what it is but let me know if anything else happens
Nov 07, 2008 | Soyo SY-K7VME Motherboard
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. [email protected]
Jun 04, 2008 | E-Machines eMachines Desktop PC
Monitor blinks no image
first you need to isolate the problem to either the computer or the moniter. I would sugust that you hook a know good moniter to the compter and go from there. If the other moniter works then you have a moniter issue aif not chek the video card in the computer. good luck
budman630
May 01, 2008 | E-Machines eMachines Monitor E15T4
AOpen F90JS (Black) 19 in. Flat Panel LCD Monitor Logo
85 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
