Question about Brother HL-2040 Laser Printer
Long silver metal bar fell out when toner was changed, don't know where it goes but toner won't fit back into space. anybody know where it belongs?
    Problem Solver:
  • 7 Answers
It is one of the toner catridge assembly ,, you have to fix it into the toner..
Posted on Apr 27, 2010
Where does long silver metal bar belong?
Clips into the bottom of the drum unit.
Aug 14, 2015 | Brother HL 2140 Laser Printer
Schlage deadbolt
Check your installation instructions. The lock is "handed" incorrectly. If on a left-hand door, it's set up for right-hand.
Jul 13, 2014 | Locks & Locksmithing
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
Spring came loose under the roller
Hi niffieprinti:
If you remove the toner cartridge again and remove the roller (Registration Roller) one side of the roller has a gear and the other has a silver bar, well one spring goes under the gear on the left side and the other spring goes under the bar on the right side of the roller. The springs apply pressure to the paper against the toner cartridge so that the image is clean and dark. if you have any further questions let me know.
Thanks
pdouglasss
Apr 17, 2009 | HP LaserJet 8150 Printer
HOW DOES THE SPACE BAR CLIP GET REINSTALLED?
Take the wire piece out of the keyboard and attach it to the space bar by snapping the long horizontal section into the notched moldings you will see along one edge of the underside of the spacebar. Now turn the spacebar back over, orient it with the high side toward you and the lower side toward the other keys, fit the retainer ends into the slots in the keyboard, and push the spacebar center pin back into its hole. The wire is not really a retainer; it is there to transfer to the center pin any pressure applied to either end of the bar.
Mar 07, 2009 | Logitech 967437-0403 Keyboard
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Changing the belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=83009&thid=695737
Changing the belt
Posted by cbgolba on Jun 22, 2008
My husband changed the belt on our vacuum, now the metal frame doesn't fit back on the bottom. Also, there is a small metal clip that we don't know where it belongs.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You should check on the owner’s manual to see how it goes together or call the Simplicity customer service line listed below to see what goes where. It’s been awhile since I have worked on a simplicity vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://simplicityvacuums.com/ Customer Service 1-888-9-Simply
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 22, 2008 | Simplicity 7850 Premier Bagged Canister...
Brother HL-2040 Laser Printer Logo
338 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
