Question about Bosch HBN 455 Stainless Steel Electric Double Oven
The oven knob has suddenly stopped working
The oven knob on my Bosch HBN13N550B oven has suddenly stopped working. As much as you turn it, it doesn't change the temperature or turn on/off, and there's no pressure there either, as though it's come away from whatever it's connected to. This happened when the oven was turned on, so now, it has to be switched off at the wall as we can't shut it off. I have purchased a new part from Bosch, just need advice please on how to fit it ?
  • 22 Answers
SOURCE: retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Posted on Jul 02, 2007
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch HBN745 Single Convetion Oven - Fan won't stop & still maintains heat
Sounds like it is the thermostat that is faulty.
Go to your browser bar and type in youtube.com
Then in the search box type in fitting thermostat to oven
Click on appropiate video and follow instructions, this should help with your prob.
Plz rate my solution.
Thanks.
youtube.com
Posted on Dec 31, 2008
barkencoa
  • 3463 Answers
SOURCE: oven has suddenly stopped working but the fan is
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Posted on Oct 11, 2009
Testimonial: "many thanks for yur help"
  • 174 Answers
SOURCE: Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Posted on Jul 23, 2010
Function selector knob loose
contact the bosch service agent for spares
Sep 03, 2017 | Bosch Ovens
Oven doesn't heat up and no light symbol shows up on the indicator panel.
it sounds like you tod stat has gone if you turn the oven off from the mains pull the oven right out and take the lid off you will see a little black stat with two wires join then up together do not let them tuch any thing then turn the oven back on if it all works afther you put the time in you will need a new one of them ok hope i have helped you
Nov 03, 2012 | Bosch Ovens
Bosch hbn 13n5.1b bottom oven temperature control knob not working
Yes they can be and if your savey they have universal oven switches that do the same thing only much cheaper than OEM parts.
Apr 07, 2012 | Bosch Ovens
Our Chef Sapphire Clock & Oven stopped working suddenly after a power failure overnight. Are there any fuses to be found inside, or any other suggestions please. The stove top is fine and all 4...
This oven needs the time set after a power failure. The LED display will read HELPME and there is a small knob on the left side you need to turn it to set to change the time and use the second knob from left side to + and once done leave the knob on manual. The oven can be timed to turn off but it the time is not set on it the oven and stove do not work.dux_training.jpg
Aug 29, 2010 | Ovens
We just plugged in our oven and it has E005 Communication error popping on the screen. Any ideas?
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
May 31, 2010 | Bosch HBN5650UC Electric Double Oven
Do the knobs on bosch ovens retract when the oven is in use
Hello, Most of the temp. & select knobs do extend out, but not automatically. If you push the knob inward and release, they should individually "pop" extend out to allow them easier to function. As I indicated this is how most modern bosch work, with the acception of some models. Please provide your actual model number if you require further help. Hope that answer's you question, let me know if I can assist you further. Good luck, please rate this solution accordingly and thanks for coming to "fixya". Macmarkus :)
Apr 01, 2010 | Bosch HBL 5032 Electric Single Oven
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Oven will not heat?
you have the oven on automatic in error. switch off at mains. leave for 5 mins. turn on, consult your handbook on how to set clock and having done this, bet it works
Jun 12, 2007 | Bosch HBN 43L550B SS Electric Single Oven
Bosch HBN 455 Stainless Steel Electric Double Oven Logo
100 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
