Question about ACCO Brands Air Tools & Compressors
I am having atlas copco make air compressor, when atarting itself the temperature is raising to high level immediately after staring, so the compressor is stoping.pls advice me,,,....the oil level is ok,oil filters also changed.pls give me a solution pls...oil cooler also is working good.
    Problem Solver:
  • 12 Answers
Need the model number and Sn# of the unit to help .
Posted on Apr 29, 2010
  • redjames82 Feb 05, 2011
    Sound like the thermostat is stuck closed and is not letting any oil into the cooler, also the cooler could be blocked.if it is not its probbly a faulty ellement (pump)
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Replace genuine oil filter. if your oil filter had a rubber check valve inside remove it.
Posted on Aug 19, 2012
  • Dee Tenebroso
    Dee Tenebroso Aug 19, 2012
    replace genuine oil filter. if your oil filter had a rubber check valve inside remove it.
We want a control panel Part No. 1604 9422 02 Xc2002 for our atlas copco air compressor XAMS 850 CD7. Can you help us on that.
we don't sell parts for anything
contact your atlas copco service center for the parts or get them from e-bay
Sep 20, 2016 | Air Tools & Compressors
Where do I get a spare parts manual for a Atlas Copco xas 160
The staff at www.aircompressordelmarva.com has all the manuals for atlas copco air compressors. You can email or call them. They posted an Adobe link for me for a really large one so I could download it. Very helpful. Delmarva Air Compressor Powered by Network Solutions
Nov 15, 2014 | Air Tools & Compressors
Have a GA7ff Atlascopco Screw Compressor. Discharge of oil from Intake & went out on heat overload.
Sounds like a bad oil seal. If the oil level is too low, it will overheat.
Jun 02, 2012 | Air Tools & Compressors
I have a ATLAS COPCO GA 160 w at my work and it is shutting down on high element temprature. I noticed that the oil level in the seperator is low and have topped it up a few times but everytime i run it...
Without more info or knowing your compressor my first question to you is,is the oil cooler clean and does the unit have good water flow. DO you have good water flow / pressure. The oil level should be about half way the sight glass running loaded. If the oil level was low ,when the thermostat opens it allows oil to flow to the cooler which lowers the oil level.Typical problems during this time of year are , , dirty oil cooler, Faulty thermostat, Faulty element temperature sensor, Low oil levels and bad oil. Also dirty oil filters restrict oil flow and can cause high element temp. problems. Try back flushing the water side of the oil cooler. Have you checked to make sure the water solenoid is opening. May have a bad coil or valve. May also have water solenoid plugged with something. What is the cooling water inlet temp and outlet temp. The W usually indicates water cooled. If not water cooled, most of the above also applies to air cooled units. just replace water with air if it fits.
Jun 28, 2011 | Air Tools & Compressors
We are using three screw oil free atlas copco compressors{ZR-275}. They often encounters the problem of high outlet temperature of first stage , almost near tripping stage. and we have to replace the...
Dear Hamza,
High Temperature at First Stage means your Second stage is becoming Weak and it is not capable to pull the maximum air from First stage, If it is only at loaded position.
If this is your regular problem you must check your Water condition it should not be below 20 degree C and not above 40 degree C.
You may also try to blow some dry air into second stage ( HP Element ) when ever it is in off position.
Hope this will help you.
Regards
Ashfaq
May 21, 2010 | Atlas Translator Atlas Copco Air Hammer...
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Air Tools & Compressors Logo
411 people viewed this question
Top ACCO Brands Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an ACCO Brands Air Tool and Compressor Expert? Answer questions, earn points and help others
